Reverse Light Switch Cable (1 Viewer)
Dubiousp
233
45
Hampshire
Eldis Autoquest
First
Ive just bought, and i have to say quite impressed a reverse camera and monitor off ebay. Quite impressed with the quality so will continue to fit on my van, so heres the question my Elddis is on a boxer chassis 09 does anybody know what colour in the front loom the reverse switch is.
Thanks in advance:Eeek:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Why not give it a permanently live feed from the ign and use it as a rear view on all the time unit when the engine is running
Geo
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Geo
That's what I did with mine, best way and I wouldn't be without it now. :thumb:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
In the drivers side dashboard fuse box at the bottom is a multi plug with lots of wires in it, one of them is green and this has a reverse light signal on it, check it out with a meter or LED test lamp.
D.
darklord
1,241
1,230
essex
coachbuilt
three years
Which one did you buy please?
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I picked up a live from the feed to the fridge.. Only goes live when the engine is running, easy to pick up as it will be behind the outside fridge vent, and much easier to run as it is a lot closer to the rear than the cab is !
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
Geo
Perhaps a naive question but if the monitor is designed for a reversing camera - ie intermittent use - would using the monitor full time reduce the life expectancy of the monitor?
Norman
Heyupluv
3,862
1,593
France,
touring many years..42+
Geo
I have the option on mine as it is built in..... on when in reverse....or... on on when the ignition comes on....I have it on all the time the ignition is on....
The one I have fitted from Rapido there multimedia station the high-tech Pioneer built into the dashboard , HD, video, cd/dvd player,radio,usb,sd,reversing camera, with a 5.8 LCD touch screen user interface...nice piece of kit :thumb:
Mel
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Norman
I would suggest it does no harm at all, maybe even better than multiple on and offs
I have a PC in the garage on 24/7 CCtv for about 6 years now, its the only one that hasn't given grief:Doh:
Dubiousp
Dubiousp
233
45
Hampshire
Eldis Autoquest
First
Reversing Camera
Thank you for all the responses, I've been away this week so will try and locate the wire in the fuse box. That said I did take the first bit of advice and picked up alive feed For the monitor and paralleled the reverse signal. The effect is that now when I turn the ignition on the monitor starts with the revers screen so I have the option of turning off. In addition I've picked a a live at the rear of the van for the camera.
In response to the unit I bought there are many around cheap and expensive to be honest for what you would need it for which is really just a sanity check I went for this cheap one of fleabay Link Removed
I'm quite impressed with it, the monitor Has a very clear image which surprised me, the camera gives a good image the only downside is the chrome finish but hay could always change the camera if I wanted
Many thanks
