Reverse camera
Discussion in 'Motorhome Accessories' started by Rgh999, Feb 6, 2014.
  1. Rgh999
    Rgh999 Read Only Funster
    Feb 4, 2014
    9
    S wales
    Am considering the instal of one into a Fiat Ducato and not sure whether to go for the 7" monitor or smaller. Any thoughts from members would be appreciated. I want to locate it on the dash on the offside and wondering if it might be too big.
  2. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,827
    3,190
    Manchester
    7 inches, Thats the size of mine (camera that is) works well.
    Too small and it wouldnt give a good view.
  3. Rgh999
    Feb 4, 2014
    9
    S wales
    Whereabouts have you positioned it. I was just concerned that it might not fit on the dash to the right as I don't want to fit in the middle of the dash.
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,954
    We have a 7 inch monitor fitted to the offside of the dash and it is fine.
  5. Larby
    Larby Funster
    Jun 17, 2012
    1,858
    4,261
    North Essex
    I have 7" monitor which clips to the rear view mirror (which is useless as I don't have rear window). Wiring tucked up under roof lining and down pillar to fuse box area.
    • Like it Like it x 1
  6. Rgh999
    Feb 4, 2014
    9
    S wales
    I'm trying to get thoughts of members as to whether the 7 inch monitor looks big and detracts or hinders their view, especially if fitted on the offside of the dash by the vents. Practically I'm sure it gives the best view when reversing but does it obstruct your forward view and create a blind spot.
  7. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,984
    1,845
    Cornwall
    Greetings,
    As a 'newbie' it was a 'must have' for us.
    It's fitted on the offside, above the vents and as well as for reversing, it is absolutely spot on in assisting as to when to pull back over into the nearside after overtaking large vehicles.
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi Larby that's what I am after but with built in GPS --got any linksplease?
    terry
  9. jemhorn
    jemhorn Funster
    Nov 13, 2013
    410
    378
    Bideford, Devon
    GPS Reversing Camera
    Hi, have Fiat with Pioneer Camera and Sat Nav combined. F130 (for trucks & motorhomes)unit with DAB radio set into the centre dash. Also can load POI's. There is a unit for sale on MotorhomeFun. Check out pioneer website.
  10. GJH
    Aug 20, 2007
    27,349
    34,954
    I've just taken this photo (from the driver's seat) of our monitor in position (it is removable to deter theft). It doesn't cause a significant blind spot and gives superb rear vision.
  11. Larby
    Larby Funster
    Jun 17, 2012
    1,858
    4,261
    North Essex
    Sorry Terry, No I don't. I bought a 7" monitor and twin cameras from the Peterborough show. I have look-down reversing and switchover to normal rear view camera.
    I have separate GPS which incidentally I have situated above the vents in the right hand corner which others earmark for their camera.
    I have uncluttered view, don't like Sat-navs on window.
    EDIT, mySat nav is located where GJH has his reversing camera as in post above.
    Peter
  12. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,757
    1,533
    West Midlands
    Another thumbs up from me, :thumb: 7" monitor mounted on offside end of dash (Transit). Does not obscure the view. Works perfectly. The mounting has a thumb screw to hold the monitor in place. In practice I do not bother tightening this, it sits perfectly still and simply slide upward for removal for security purposes.:BigGrin:
    Wyn
  13. themogs
    themogs Funster
    Oct 23, 2012
    863
    908
    Wales
    :Smile:We have a Bessacar E510 Compact with a reversing camera as standard (Blaupunkt). But it only comes on when reverse gear is engaged.:RollEyes:
    It's OK, but would be better if it could be in use at all times !!:Doh:
    Just a little tip !!!:Wink:
  14. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    703
    409
    Rugby UK
    Iveco chassis and have the 7" screen centre mounted on the dashboard with a satnav sitting on top of the dashboard above, when I had it fitted the guy was going to link it to the reverse gear for auto changeover but I toldhim to fit a rocker switch instead so I can check the trailer hitch / bike rack while in motion, one of my better moves. 7" screen is just the right size.
  15. Steve
    Steve Funster Life Member
    May 8, 2013
    1,615
    2,035
    Compton Berkshire
    I did the same with mine, then it fall off:cry: mirror and all so now in same position but suction cup and support from sun visor seems ok now.
    Steve
  16. Rgh999
    Feb 4, 2014
    9
    S wales
    Thanks to all who have replied. Looks like the 7 inch on the dash offside is quite popular and doesn't cause any sort of obstruction. I'm thinking of going for a Digi max wireless camera from trailervision.
    I know you'll all say wireless are no good, and tell me the ease and benefits of wired, but the claims of digital wireless are documented and I'm willing to give it a go to save running wires back to front.
    Time will tell
    Thanks again guys.
  17. PaulyP
    PaulyP Funster
    Jul 29, 2011
    1,827
    3,190
    Manchester
    Sorry for the late reply - on nights.
    My screen sits in the middle of the dash and does not obscure when driving, it actually folds down within its own box when not in use.
    I have a 7" trucknav which sits to the right of the drivers seat and also is well positioned.
    My reversing screen is easy to see and in line of sight as i also use the wing mirrors a lot as i dont have a view through to a rear window.
  18. daisy mae
    daisy mae Read Only Funster
    Mar 12, 2013
    676
    596
    Leicestershire
    I have this week had a 7" rear view monitor and twin cameras fitted, and they are brilliant, wired so that when ignition is turned on the rear view is on ,when I want to reverse into tight places I switch to the other camera by monitor or by remote controller, , didn`t have this connected to the reverse in case I wanted to use the other camera and it cannot be over ridden in that case, :thumb:
    It is a very neat job, all wires hidden through van, I did have it professionally installed though.
    I couldn`t do with a dash board monitor, wouldn`t be comfortable for me.already have a sat nav on there didn`t want the hassle of having to remove two monitors every time I park up either, I do use it every day.
  19. jackrussel
    jackrussel Read Only Funster
    Jul 8, 2012
    54
    47
    south cheshire
    I'm sure some of the 7 inch chinese truck/RV satnavs on ebay have camera inputs, for wired cameras. Not sure how they are switched or selected, but they are pretty cheap and get good satnav write ups on here.
