replacing tap ?
Discussion in 'Motorhome Chat' started by greyman1, Jun 19, 2012.
  1. greyman1
    greyman1 Read Only Funster
    Aug 7, 2011
    363
    273
    manchester
    i am going to remove the shower tap in my hymer .if i run the tap {without the pump on } will this just drain the pipes to that tap or do i have to drop the water in the tank ? do i have to do anything with the heating boiler ? i fear this straightforward job might be escalating ! [it is a microswich in the tap system by the way] cheers guys
  2. chrisgreen
    chrisgreen Funster
    Jul 26, 2009
    5,668
    7,792
    england
    No need to drop the water out the tank as you have a none pressure system,just ensure that all power is switched off ,and remove tap there will be a small amount of water but not much:thumb:
