Replacing cassette toilet
Discussion in 'Motorhome Chat' started by Huddersfield123, Feb 23, 2015.
  1. Huddersfield123
    Huddersfield123
    Jan 16, 2013
    15
    16
    Yorkshire
    We are looking to add a toilet tank to our Carthargo M liner does anyone have any contacts for a company who can help.
    Many Thanks Huddersfield 123
  2. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,373
    1,458
    Suffolk
    Great idea----I have been looking at this----CAK tanks comes to mind first-----there are others---look at marine toilets---and RV places--If you go this route, factor in a macerator, you won't regret it, there are not so many ground level dumps, a macerator allows you to dump almost anywhere very easily/cleanly.
    You would ideally plumb the grey tank through the macerator to flush it with 'clean' water.
    Go for the biggest tank you can fit in----don't factor in the gross weight of a full tank in your GVW---you won't ever/ often DRIVE with it full, if you are a bit of a DIYer you could do it yourself.
    Nigel & Pamala
    • Like it Like it x 3
  3. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    I looked at doing it but decided it was too expensive and complicated so opted for a spare cassette instead, think I've only had to use it a couple of times though.
  4. Sundowners
    Oct 30, 2007
    2,373
    1,458
    Suffolk
    We do have a spare cassette, but after using a black tank for several years I believe that the cost of changing from cassette would be well worth it-----------personally I think that fitting cassette loos in mid to large motorhomes is just a cheap bodge--------OTOH a lot of EURO vans would not have enough room to fit a worth-while tank:(--In this case there wouldn't be such an advantage
    Nigel
    • Like it Like it x 1
