replacing a cv boot
Discussion in 'Tech/Mech General' started by Wildbill, Feb 18, 2015.
  1. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,887
    somewhere
    Think I might have to replace a cv boot on my van having never done one on a fiat I suppose I will have to remove the hub.
    so just wondering if it would be worth changing the wheal baring at the same time as I have two new ones.
    I got for my last van but got away with putting them in.
    BILL
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,574
    YO11 2BD
    While its in bits Bill, and you have the bearings (check they are correct for your van first) it wont hurt and could save having to strip it again later.
  3. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,887
    somewhere
    think that's the way to go john thay are the right ones fom my van
    thank for the reply @pappajohn
    • Like Like x 1
  4. Zains Pops
    Zains Pops Funster
    Sep 10, 2013
    731
    4,423
    Chelmsford Essex
    Have a really good look at the cv joint, it is usually best to change the whole shaft rather than just the boot as any boot failure will have allowed dirt and contamination into the joint.
  5. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,887
    somewhere
    it is just got sum cracking it has not gone completely
  6. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,887
    somewhere
    I would just get a cv joint kit
  7. Tootles
    Tootles Funster
    Sep 14, 2013
    9,134
    32,586
    Lancaster
    Last CV boot I did, cut it down the middle, (top to bottom), with a craft knife blade, pulled off the old one, and cleaned everything up. Freed the jubilee clips, put the new one around the shaft, and joined both cut sides with superglue. Replaced the clips. Quick and fast if your short on time. :)
  8. pappajohn
    Aug 26, 2007
    29,903
    17,574
    YO11 2BD
    Could buy universal kits the same as that a few years ago....slit up one side, place over joint and superglue together.
    if you were lucky it would still be there next day.....biggest load of junk ever.
    • Like Like x 2
  9. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,887
    somewhere
    I have used the universal ones before but never had on last Moore than six months before I had to replace it
    bill
  10. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,887
    somewhere
    got lodes of time toot's sooner it was right for a trubile free spring and summer it will only tak two or three hrs
    bill
    • Like Like x 1
  11. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,084
    9,689
    Lorca,Murcia,Spain
    You can't do the cut down on the Fiat even if you wanted to as , & I assume Bill's would be same as mine, the outer end of the cv boot where the metal band goes has to be assembled before the hub is put on as it then covers he end of the rubber gaiter.:( Ask me how I know ? :LOL:Hit a pothole in North Devon whilst over last year & when I checked it had dislodged the whole outer end & band. :cry:
    • Like Like x 1
