Replacement turn wheel for grey water valve. (1 Viewer)
Bushtrekker
253
120
Cannock, Staffs
Hymer Tramp
Second time around.
The MOT was done this morning and apart from some welding it was fine. The small wheel controlling the valve for the grey water tank has disintegrated and I haven't got a clue where to start looking for a replacement. Does anyone know if caravan shops might stock these, as although I can't see it being a regular occurrence they must go occasionally?
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Yes they should sell them but if not take it to your local plumbing suppliers,they will soon sort you out :thumb:--Plumbing S may well be the cheaper option :winky:
terry
TheBig1
17,630
43,265
i havent got round to it yet, but will be replacing the ones on my van for lever valves. much better than the cheapies fitted by the original converters
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
You can't beat a good gate valve!:Smile:
TheBig1
17,630
43,265
this is what im fitting..... an easy to use lever on a ball valve to prevent restriction
Link Removed
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Link Removed
Same as I fitted almost 6 yrs ago :thumb:Simple to fit and never a problem-I also carry a 3 mtr length of 22mm hose that simply screws on in case I do not get close enough to empty point :thumb:
terry
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
A ball valve is better :winky:::bigsmile:
Bushtrekker try a search for ball valve and bore size :thumb:
terry
Ahh but it depends how much of your holiday you want to spend watching your grey water drain!
Our waste tank has a 105 litre capacity and empties in seconds through a 2 1/2" gate valve. The rapid drain down and the fact the valve is on the bottom of the tank ensures most of the residual crud is emptied too!:thumb:
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Only had 22mm laying around when I did the build ::bigsmile: Usually fill clean tank while emptying the other :winky:
terry
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Hi Terry
We used a 22mm ball valve on our old Elddis as a cheap upgrade to the woefully inadequate beer-barrel tap previously fiited by the manufacturer.:thumb:
The performance of the old one was laughable! It was another example of how some manufacturers don't seem to have a clue as to the use their products will be put to!:Angry:
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Hi John and Shell the 22 mm does OK plus I had /have plenty of 22 mm hose to trip over in the garage :thumb:If I am on the last empty before home bound,I empty the loo cassette at the same time so the tank is normally well empty before I have done the loo :thumb:::bigsmile:Ann does her bit by having wet ones for my hands before she lets me back in the van :Doh:
terry
