Replacement interior bulbs (1 Viewer)
Billy23
1,610
2,984
On a planet...far, ....far away.
On and off 1995
I have heard that it is a good idea to change the "ordinary" interior bulbs in the motorhome with, I think LED ones (Might be wrong as I really don`t understand electric). Could somebody please point me in the right direction as to the type and best buy.(y)(y)(y)
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
http://www.atenlighting.co.uk/caravan-motorhome-lighting
Quality stuff. Fast delivery. Excellent aftersales. (y)
You should be able to find most of what you want there. Beware of cheap cr*p Chinese ebay led's. They are often polarity sensitive, which could leave the lamp facing the wrong way and often have a limited voltage range and usually a limited life.
D
Deleted member 29692
It depends on your existing lights fittings.
With most of them you will just be able to change the lamps to LED ones but there are quite a few different types so obviously you will need the correct ones.
There are a few types of fittings where you won't be able to do that and will have to replace the whole thing.
If you post what fittings you have, or better yet pictures, someone will be able to point you in the right direction.
musson
487
165
grantham
low profile
since Jan 2014
Change them all to LEDs there are different grades Warm white etc,also if you take children with you and they touch the bulb led will not burn them,
Dec 11, 2011
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
just to follow on from what @musson has said, make sure you look at the colour of the light that the LEDs emit. The warm white ones are more like the colour of light that you get from your existing incandescent bulbs. I find the light from the cool white ones a bit too 'clinical' but it's down to personal choice.
RowleyBirkinQC
2,345
225,774
Dazed & Confused
GJH
29,450
38,827
None, now sold
2006 to 2022
One of the first jobs I did in the Burstner, when we bought it 4 years ago, was to replace all the bulbs with LEDs. The lights we use mainly are four spotlights and two ceiling fittings. Having used Aten products previously I bought LEDs for the spotlights from them. The ceiling fittings were a little "tired" and the most suitable replacements were from Ledbulbs4u.
For the lesser used fittings I decided to try eBay suppliers (both China and England based) as they were significantly cheaper - the LEDs have worked fine so far but they are less robustly built than those from Aten and Ledbulbs4u.
EDIT - A decision to be made with LEDs is whether to use Warm White or Cool White - very much personal preference. The easiest place to compare is at a motorhome show where several suppliers will have both on display.
treetops1
1,599
1,759
yorkshire/ lincolnshire.
Sold last van-
a long time,since 1996
We have cool white in the toilet/shower room warm white elsewhere,Got the cheep Chinese ones and a few spares 99P 3 years ago ,
Jan 12, 2016
300
2,063
Amble
adria izola
since 2014
Just changed our lights to leds ,what a difference ,should have done it ages ago.
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
I found this out when replacing halogen bulbs for led in the roof lamps in my caravan a few years ago. Each lamp had 2x bulbs, I had to turn 1x lamp holder through 180 deg in each of the 5x roof lights due to polarity, so that the lamp was facing the right way. I think all led lamps are polarity sensitive so don't immediately think a new led bulb is u/s if it doesn't illuminate. Try it the other way around, you may just have to unfasten the lamp holder and turn it 180 degrees as I had to. That was with G4 type bulbs.
Wickolad
490
542
Wickersley
Ditto, I still have the spares too, albeit not as many as I had due to replacing a couple of friends lights when their halogen bulbs had popped.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
All those sold by Aten Lighting are not, and will work whichever way round they go in. One reason, I suppose, that they cost a bit more.
Shrimp
May 27, 2015
3,981
33,305
Bedfordshire, UK
Hymer B584
Long time
We changed ours few years back, cool & warm light in washroom, cool ones in overhead then warm light in side downlighters, Hymers have a lot of lights!
They save a lot power, invaluable when on Aires in France!
Aug 18, 2014
23,741
133,203
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
All mine are Hong Kong Fuey's top quality chinese tat. Never had a problem with either the bulbs , which the bloke previous to me had changed to, or the interior lights which I changed to the led on boards type varying between 4 & 20 led's on a board.
Never had a problem with the polarity as the wires are red & black :) Prices are excellent unlike buying them from a car spares shop here or a Bosch,Lucas,Magnetti,Marelli dealer where you need a mortgage. The only alternative is ship them from the UK.
Nov 2, 2014
331
295
Maldon Essex
10x G4 6/9/12/24 SMD LED Warm/Cool White Lamp Home Marine Car Boat Light Bulb DC
eBay item number:151349749382
The 9 SMD Warm white are about 24mm diameter plus the legs polarity neutral so fit any way.
I have fitted around 50 of these to mine and friends vans with no problems.
£5.49 for 10 not £5.49 each.
Shipped from the UK
Chris
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
Current and last van have Chinese Leds from ebay, no problems so far, some are polarity sensitive but you just change them round. One thing I did find was some Chinese MR11 bulbs have G5.4 bases instead of our standard G4 whch can be a problem. I have also found some of the 5w5 bulbs a bit iffy which is strange when all the other styles are OK. We also are now about 90% LED at home as well. A friend change his high power security lighting which is tripped many times a night by wildlife to LEDs and his leccy bill fell noticably.
Of course you can trade the power saved for more light, I have changed one light in the Bongo to a similar powered LED and the interior light is now worth having.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
You might find that some do not work, that is because they are diodes and only pass current one way so the wire might need swapping over on the holder, two were like tha on mine when I changed the bulbs to LED, the batteries last a LOT longer with the LED as the current draw is way smaller than the halogens on the spots.
Billy23
Billy23
1,610
2,984
On and off 1995
The ones I ordered are out of stock, they are G9 and fit into a converter. I now need to reorder, I see that they seem to come in different watts, could one of you kind gentlemen tell me what watts I need please.
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
A bit of internet research will offer a comparison between light output from conventional vs LED - normally expressed in lumens. From that you can determine how much light is available from the different types.
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
An LED of about 1/5 the wattage of a halogen should be OK but some labelling is a trifle optimistic. For example I use 9 watt in place of 5 watt in the house and often 3 in place of 10 in the van. A little playing around soon gets things sorted.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
You can also buy them for your house under the label GU10 if you have the stubby bayonet type. I've done our kitchen, so instead of using 320 Watts of "trickery" in the 8 spot lamps when we turn on the overheads, its just 24 Watts.
Yes I am careful. ((tight))
Mitch. ;););)
