Replacement Door for Bessacar E795 (1 Viewer)
AlphaPets
36
Newport
Bessacar E795
Hi All,
Now that we have been out and about, we would like to replace our existing door with the stable door type. Can these be sourced from a breakers yard? If so, recommendations please.
:thanks:​
A
AlphaPets
36
Newport
Bessacar E795
Can the existing door be converted? :rain:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i would say that all they do to make the stable door is to cut it in half then fit aluminium edging and a locking device.
TheBig1
17,575
42,958
not on most modern doors with 2 point latches, it would mean cutting the internal mechanism in half
as for fitting a second hand door...thats a whole can of worms even if you could find one. they distort and go out of shape too easily
rainbow chasers
3,680
1,725
Mid Cornwall
Various
You would need to measure up, and then have a look at what german van doors would fit. These can be sourced from breakers, but are not as cheap as you would think! I beleive they are around £600 new, so a breaker could easily charge £200.
Also, another consideration is the texture of the door, as most conti's have textured sides to prevent ice/snow sticking.
Conversion would be the easiest option, assuming the latches are single point - or you could convert to single point ones.
A
AlphaPets
36
Newport
Bessacar E795
Had a guy looking at our Motorhome and pointed out that the door adds to the rigidity of the motorhome.:Confused:
