Replace Flooring Lino (1 Viewer)
Wollow007
36
Reading
Swift Sundance 630g
Im a newbie
Hi All,
Anyone know of somebody who could replace the Lino in my motorhome?
The Lino had to be cut to replace some floor after a leak, would like to get the flooring replaced s the cut section looks a little unsightly.
I would have a go myself but the lino was installed under all the fittings and furniture, so i guess the easiest would be to cut it out and cut the new lino in.
Any dvice always welcome :thumb:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Hi All,
I recently had the carpet taken out of my motorhome and replaced with vinyl by CareAvan of Birmingham. They did an excellent job.
W
Wollow007
36
Reading
Swift Sundance 630g
Im a newbie
Wow that looks like a superb job, will give them a call Monday :thumb:
TheBig1
17,617
43,198
most local vinyl fitters will give you a quote. the hardest part is removing the old vinyl if glued down. have done the job before myself
run a stanley knife round the edges first
then warm up the first edge with a hot air gun and start to peel back
move forward and warm next few inches
repeat till vinyl is removed
scrape up any lumps of glue with a very sharp wallpaper scraper
clean the floor thoroughly and allow to dry
refitting is a case of cutting replacement vinyl to fit
then roll back to centre and apply suitable glue to first 12inches from centre
wait till glue is tacky
firmly roll down the corresponding vinyl
repeat till you get to the end
the roll back other half and repeat above
seal edges and joints with correct coloured sealant
it can be done DIY but a pro fitter will take half the time to give a good finish
W
Wollow007
36
Reading
Swift Sundance 630g
Im a newbie
Thank you for the info, I quite like the idea of someone else doing it. The removal sounds ok but cutting it back in place worries me a little. Also if it starts peeling up after six months I can throw it back at whoever installed it :winky:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Your welcome to give Glen, my service manager or Ian a call and ask them, we can do your window at the same time being Swift dealers:thumb:
01-580-881288 option 3
Peter
W
Wollow007
36
Reading
Swift Sundance 630g
Im a newbie
Hi Peter,
Can you guy's replace the lino also?
If you can do both it might well be worth bringing it down to you guy's :thumb:
