Repairing An E-Z Lift Pleated Blind
Discussion in 'American RV's' started by scotjimland, Nov 28, 2008.
  1. scotjimland
    Jul 25, 2007
    28,934
    25,601
    E-Z Lift Pleated blinds, commonly fitted to RVs, are very reliable but sooner or later one of the four nylon cords will snap.. as happened to us this summer..
    They are easy to repair, if a little daunting at first:
    You need:
    Nylon cord, available from most hardware, DIY shops
    Large darning needle.
    Lots of Patience..
    A bit of gumption.
    1.Remove blind
    2.Lay out on a flat surface, closed.
    3.Carefully remove the three long covers on the top rail and bottom of both blinds.
    4.Remove broken cord and rethread using the darning needle, this makes it easy to thread though the pleats.
    5. Tie off both ends.
    6. Replace covers
    7. Re hang blind and tension the cords :Smile:
    Attached is a drawing of the cord routes, (just in case you pull them out and can't figure out how to re thread. ):Doh:
  2. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    Excellent.
    Problem is with mine the strings still OK just need to get it onto new toggle.
    Where do you get replacement string from BTW?
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,883
    17,542
    YO11 2BD
    there you go john. :Doh::Rofl1::Rofl1::thumb:
  4. Road Runner
    Jul 26, 2007
    14,196
    1,459
    Europe
    Der:Doh::RollEyes:
  5. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,356
    1,442
    Suffolk
    I have not done one of these (all the ones in the 5er went to the tip!) But the one that I did fix, I seem to remember pulling the new strings through with the (unbroken) ones, it saved a lot of fiddling.
    If we can help, at the new-year meet, we will.
    Nigel & Pamala
  6. scotjimland
    Jul 25, 2007
    28,934
    25,601
    Just for pappajohn :Wink:
    I believe Dunc (Starspanglespanner) has the correct cords
  7. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    been there, done it
    Darren of Motorhome medics (on ebay) or 01452 856856 - www.rvspares.co.uk has a kit for the 4 string and 2 string type. The kits is RV Shade Repair kit and comes with a DVD.. the cord is 130 lbs HTFP cord.. the kit has the replacement plastic washers as well as the cord. - 2 string kit does 2 windows and cost £16.99 inc postage off ebay..
    Not an easy job to do.. had to use a paste table to support it and needed 8 pairs of hands.. Sue helped me.. had to do it twice as it is easy to tangle the cords in the cross over.. make sure they all cross the same way under or over otherwise you will have to do it again as I have found out to my cost.
    Have fun..
    Bob:thumb:
  8. scotjimland
    Jul 25, 2007
    28,934
    25,601
    :Eeek: for a bit of nylon cord ...
    now that is what I call a rip off
  9. slobadoberbob
    Jun 1, 2009
    6,159
    1,970
    but it is the same colour
    Yes, Jim expensive.. the cord is the same colour as on the van a buff colour.. the DVD is crap and goes so fast through the photos for a dozen different set ups. But I found it is easy to work out... the cords run across as shown at the start of the post... Just time consuming and need a lot of hands... took me a couple of hours, hardest part was getting it out of the van where it had been screwed in place.
    But I agree expensive..we did try to get a suitable heavt duty cord, but did not find it anywhere... looked in the UK and France when it broke.
    Bob:Eeek:
  10. motor roamin
    motor roamin Funster
    May 23, 2010
    1,535
    785
    Leicester
    Shoulda got ezzie to do it lol
    Cheers Rick
  11. slobadoberbob
    Jun 1, 2009
    6,159
    1,970
    to m uch slobber
    Morning Rick... Ezzie has to much slobber ..but could have used her paws to hold it in place while I tried to thread it.
    Note still no Avitar for your posts... you are not ashamed to put a picture of your bus up I hope?:Rofl1:
    Bob
