Renault traffic 1985 (1 Viewer)
froghopper
412
181
winchester
c class
before they were invented
Good evening, this is serious. And I really need help. For a while now I have had a fuel problem, long run short run hot or cold. Engine starts, drives about 300 yards then peters out. Have tried lots. Plugs. Electrics and associated parts. Changed carb. Fuel filter, fuel pump. If I take pump off, press plunger and replace, engine starts, if I don't press plunger it often starts. Off to France next Monday,,, help,,,, if I take rocker cover off ? Will I find a slide from cam that is stuck, what pushes the pump slide in and out,,,,?....?? Sorry it's a lot to ask. But. Running out of options, cheers froghopper
keithcdb
98
48
scotland
Iveco
newbie
Could be worth checking the vacuum pipes from the inlet manifold and the inlet manifold gasket. Drawing in extra air could be your problem.
Hope you get it sorted :thumb:
Apr 13, 2012
5,543
18,772
Mobilvetta Euroyacht
1996, then break 'til 2011
Have you tried draining fuel tank, an old van of mine had water in the petrol (condensation from standing).
Feb 16, 2013
19,731
52,009
uttoxeter
ambulance conversion
50 years
Definitely look in tank small filter in tank pulling muck in then letting it drop again when it stops over and over seen it many times
