Renault semi auto gearbox
Discussion in 'Tech/Mech General' started by jtp890, Oct 5, 2015.
  1. jtp890
    jtp890 Funster
    May 16, 2014
    315
    262
    wakefield
    Having parked van on a steep slope for 4 days, problem engaging drive in reverse. Slowly pulled out but problems engaging 1st. Coasted downslope and parked on level ground, half hour later all well.
    Travelled home 1200 mls no further problems.
    Is this a fluid problem level , anyone had similar experience.
  2. ivorantony
    ivorantony Funster
    Jan 22, 2013
    514
    547
    London SE
    I have the same gearbox and found if you leave it in gear on a slope the handbrake on the Renault master allows a slight creep,
    This effectively loads the gearbox and the gear change servos find it difficult to pull it back to neutral,
    so I simply chock the wheels and leave it in neutral, if I have to use the levelling blocks I get it level and the missus chocks the wheels,
    simples(y)
    hope you had a good holiday
  3. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,392
    10,334
    Lorca,Murcia,Spain
    Certainly sounds like one. Is the level correct ?
