Renault Master horn
Discussion in 'Renault' started by Kanberlingo, Jul 2, 2009.
  1. Kanberlingo
    Kanberlingo Read Only Funster
    May 18, 2009
    91
    Lancashire
    Hi, Is anyone out there that can indicate where the horn is situated on a late 2007 Master. My Chausson Allegro83 is on this base vehicle & I want to fit the air horns that I took off my previous MH. The horn on the Chausson sounds like a cat, that's had its dingly dangly's squeezed. :Eeek:
    I'll be taking the feed from the horn as the feed for the relay switch, when I can find it.
    I know it's in the engine compartment :Rofl1:but where?
    BeeJay
  2. gazznsam
    gazznsam Read Only Funster
    May 15, 2009
    273
    Eastwood, Notts
    where ever it is, it'll be in such a place that you make the noise of a cat with it's dingely-dangelies being squeezed as you try and get to it :Laughing:
    usually they are behind the bumper tho, get someone to press the hooter button and have a listen.
  3. thewilse
    thewilse Read Only Funster
    Jun 9, 2009
    3
    on our master it's on the the left hand side stalk... at the end... with the 'horn' logo:Laughing:
  4. Kanberlingo
    May 18, 2009
    91
    Lancashire
    There's always one. Must be the weather:Wink:
    I've obviously tried that gazznsam, but no joy. On my last MH, the AutoSleeper Executive, I had to dismantle the front grill & remove the N/S headlight just to get at the wiring for it.
    If I can't sort it, which I will,:Cool: I'll open a window at the appropriate time of an impending "coming together" & get SWMBO to shout. That'll shift 'em.
    @ thewilse, & before you ask why she'd shout "That'll shift 'em" ..............:Blush:
    BeeJay
  5. stagman
    stagman Deleted User
    I know this is a bit late but seeing as you not had an answer .The Horn is under the Pass side front wing not under the bonnet:thumb:
  6. Kanberlingo
    May 18, 2009
    91
    Lancashire
    Hiya stagman,
    Thanks for the belated info. Good on yer! I should really have posted up, that I'd sorted the horn jobbie. I decided to get off my backside & take a proper look see after my last post. :Blush: If I'd done that in the first place...........
    It's in such an easy position that I've fixed the air horns, compressor & relay to a bracket, so they can be removed in one lump, in minutes, for when I swap this MH for the next one.
    BeeJay
