Renault master 07
Discussion in 'Tech/Mech General' started by Darren, Oct 11, 2016.
  1. Darren
    Darren Funster
    May 27, 2014
    109
    20
    Canterbury Kent
    I have a Renault Master which has twice gone into limp mode and has put warning lights on the dash indicating water in the fuel. I have used the tank of fuel and replaced the filter but I have had it go into limp mode again showing the same warning lights. I can get it to clear by turning the engine off and back on which then puts everything back to normal. Anybody else had these Symptoms?
  2. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,301
    3,104
    Kendal, Cumbria
    The sensor is normally in the base of the fuel filter. Might be worth changing it
  3. Darren
    Darren Funster
    May 27, 2014
    109
    20
    Canterbury Kent
    I don't seem to have a sensor in the base
  4. jtp890
    jtp890 Funster
    May 16, 2014
    332
    272
    wakefield
    I had similar problem, engine went into limp mode, no warning lights, stopped at services, all clear on restart.
    Ran ok for 2 years then had similar problem this year, AA reackoned EGR fault, dissconected electrics to EGR and van runs fine.
    Search Renault forums and limp mode - electrical problems are common fault.
    Good luck
  5. Darren
    Darren Funster
    May 27, 2014
    109
    20
    Canterbury Kent
    Cheers I will take a look at Renault forums
