Removing vanity fitment in bathroom.
Discussion in 'Tech/Mech General' started by Janine, Jul 30, 2012.
  1. Janine
    Janine Funster Life Member
    Aug 22, 2007
    5,083
    8,216
    Sunny Shropshire
    We seem to have a grey water leak which I'm assuming is a leaky pipe from the sink in the vanity unit in the bathroom. This consists of a drop-down sink with a glass-fronted cabinet over, mounted above the bench loo.
    I can see no screw heads so am I right in assuming it's stuck on and sealed round the edges?
    What's the safest method for removing it without causing any damage?
  2. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,452
    6,405
    St. Helens MERSEYSIDE
    leaky pipe
    Hi.Janine I had a caravan some years ago with the same problem check if you can get to the back of the unit possibly inside a cupboard their may be service panel which can be removed if not it may be time consuming trying to get a large plastic fitting off without breaking it good luck:RollEyes:
