Removing stainless wheel trims
Discussion in 'American RV's' started by Larrynwin, Jul 3, 2008.
  1. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,679
    13,212
    Norfolk
    Hi all
    I have recently obtained a Hurricane 30q triton. How do you remove wheel trims for wheel changing. These are 19.5 inch wheels and the ss trims have no external screws. One of the nut covers has a cut on one face.
    Is there a special tool for removal, please help
    Larry:
  2. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,606
    11,271
    Taunton Somerset
    Hi Larry probably two of the nuts are "real" and hold on the trim. The best way to check is to move the nuts side to side by hand. Those that flex the stainless steel are the dummy ones and the ones that feel solid are the "real ones" that hold the trim on by screwing onto the exposed part of the thread above the original nuts.
    There is a special tool to remove them, but this is at best a plastci coated socket. Find a socket that is the exact size, ensure that there is not grease or grit in the socket or on the "real" trim nut and you will be fine. The are not capable of being torqued up to the same as the original wheel nuts under the trim.
    Hope this helps
    Eddie
  3. Tony Santara
    Tony Santara Funster
    Jul 26, 2007
    1,494
    114
    Cheshire (ex Mancunian)
    Hi Larry
    Eddies correct there are 2 types of trim for these RV's " clip on " like the ones on cars that just pull off and " bolt on " the ones Eddies explaining to you,the 2 opposing " dummy " wheel nuts hold the trim in place on a stud extender that fits to your wheel behind the trim, you should have had a T shape socket wrench with the bus for removal purpose if not then find a socket to fit they don't need to be as tight as a real wheel nut
  4. Lampie
    Lampie Read Only Funster
    Nov 2, 2007
    169
    Derby
    The two chrome nuts with a mark on will be opposite to each other on the wheel, on mine these just pull off. behind them are nuts that hold the trim to the wheel.
    Regards
    Lampie
  5. Jim
    Jim Ringleader
    Jul 19, 2007
    26,116
    77,207
    Sutton on Sea
    I used a Spanish Peage to remove mine, when i didn't have a Peage handy a welsh sheep trailer did the trick.
    Hope this helps:Rofl1:
  6. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,679
    13,212
    Norfolk
    Thanks all i'll give it a go, with the exception of the sheep!!
    Larry
  7. eddievanbitz
    Oct 4, 2007
    3,606
    11,271
    Taunton Somerset
    Ah Yes I'd nearly forgotten Jim, didn't you (Edit) ALSO learn a way of removing them on your drive on the way home from Travelworld on your inaugural trip:Rofl1:
  8. Jim
    Jim Ringleader
    Jul 19, 2007
    26,116
    77,207
    Sutton on Sea
    :Blush::Blush:
