Removing Satellite System
Discussion in 'Motorhome Chat' started by enjohn49, Feb 23, 2015.
  1. enjohn49
    enjohn49
    Feb 15, 2015
    28
    9
    Northamptonshire
    Hi, can anyone help me with the removal of a Oyster Vision satellite system please? I am about to change my motorhome and am going to remove the system myself. I have removed previous systems before, however I am not sure of how to remove the control panel as it is different to the last one I removed. The system is about 3 years old and has the small control panel with 3 buttons at the bottom. I think it may just be stuck on, but I don't want to attack it and then find that it was screwed on! I suspect it would all end in tears!!:cry: Any guidance on this would really be appreciated. Thank you
  2. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,853
    12,002
    Taunton Somerset
    There are (should be) removeable panels either end that clip on. There will be screws behind the two panels. There is also a slot for an SD card should the system ever need updating
    Thats the easy bit.
    Removing the roof panel cable and gland will make you sweat. No tricks just a chees wire, blades and a selection of scrapers to do the job
    Good luck ;) post if you need more help
    • Like it Like it x 1
  3. enjohn49
    enjohn49
    Feb 15, 2015
    28
    9
    Northamptonshire
    Thanks for your reply. Are any type of blanking plugs available for the entry gland?
  4. eddievanbitz
    Oct 4, 2007
    3,853
    12,002
    Taunton Somerset
  5. enjohn49
    enjohn49
    Feb 15, 2015
    28
    9
    Northamptonshire
    Thanks once again. The other alternative I had considered, was leaving the cable then renewing when refitting the system. I have also sent a request for a quote.
  6. eddievanbitz
    Oct 4, 2007
    3,853
    12,002
    Taunton Somerset
    That will be expensive. We tend to leave the plate as it is more cost effective for our customers to buy a new one than pay us by the hour to remove it. if you have plenty of time that is a different matter.
  7. enjohn49
    enjohn49
    Feb 15, 2015
    28
    9
    Northamptonshire
    I will remove the old system myself but would need to have it refitted professionally. I have just looked at the control panel and it appears that the installer decided to stick the unit (with self adhesive pad?) instead of fitting it into a housing!
