Removing radio from Fiat Ducatto (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
I have a radio on my 2006 Autotrail Tracker SE (Fiat Ducatto) that I need to get at to fix a screw that has come loose. It is underneath a pull up, hinged clipboard thing, and I have removed two screws very close to the windscreen at the back of it but nothing appears any looser. Any ideas anyone? Many thanks, Jerry
old-mo
Extra Special
16,343
93,562
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
If it`s a modern radio... ie the last 6 - 10 years you will probably need one of these and not need to undue any screws/brackets etc..
old-mo
Extra Special
16,343
93,562
Weymouth. Dorset...
Sorry... should have added..
If the radio has two (2) small holes on each edge of the thin side just poke them things in and push and the radio slides out of it`s housing.. :thumb:
Feb 16, 2013
19,684
51,817
uttoxeter
ambulance conversion
50 years
If you havnt got them things four two inch nails will do same job:thumb:
Aug 6, 2013
11,949
16,550
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If you do need to remove the clipboard and its base you need to remove the radio first (method explained in other posts) then you need to remove the radio 'cage'. Once that's done there are two screws visible that need to be removed. Then the whole assembly can be lifted out.
