Removing Drivers Seat x250 Peugeot Boxer (1 Viewer)
arthur49
112
168
Perth, Scotland
PVC
30+ years
Anyone removed the drivers seat on x250? I want to remove it to install a 2nd leisure battery there......makes it easier.
Looks to me like two bolts at the front need to be removed. Then the seat slides forward and lifts out? But what's the electric cable? Seat belt pretensioner? And what to do with it?
Arthur
Oct 14, 2007
3,988
6,247
Rochester
Auto-Trail Mohawk
16 fun filled years
I removed the front passenger seat to fit a swivel, I would assume the drivers seat is the same with the four bolts you mentioned, but I have a niggling suspition it may be six bolts. The wire will have to go back as it came out.:thumb:
dshague
996
302
VAN CONVERSION
20 years
you have to remove the cable just separate the jack plug .:thumb:
43,323
49,440
Unless things have changed there are the two hexagon bolts as mentioned, slide the seat forward and in the runners, at the back, are two more Torx bolts.
the seat is heavy so take care when undoing the last bolt :thumb:
