Removing Captain's Chairs
Discussion in 'Motorhome Chat' started by maz, Apr 12, 2015.
  1. maz
    maz Funster
    Jan 26, 2011
    2,534
    2,173
    Out there somewhere
    We'd like to remove the two swivelling captain's chairs in the cab to get at the batteries hidden below. Can anyone explain in simple terms what we need to do to get the chairs off without damaging either them or ourselves? Which bolts to remove first etc? Van is based on a 2010 Ducato. Thank you.
  2. smiffy502000
    smiffy502000 Funster
    Aug 5, 2012
    220
    118
    sutton coldfield
    hi, im sure if you go on u-tube someone will have posted a video. have a look at fitting seat swivel, it shows how to remove the seat. what I cant understand is why the batteries would be sited with no way to maintain or renew them without removing seats ? also the seats are very heavy watch your back
    • Like Like x 1
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,943
    17,608
    YO11 2BD
    On my last Ducato.......
    Slide the seat right back and undo the two bolts on the front of the seat box Holding the runners
    slide the seat right forwards and undo the two bolts INSIDE the seat runner.
    the rear ones may or may not be star bolts needing a six point spline driver.
    The seats are heavy and cumbersome so take care.
    • Like Like x 2
  4. pappajohn
    Aug 26, 2007
    29,943
    17,608
    YO11 2BD
    Convenient and very secure location.
    • Like Like x 1
  5. Abacist
    Abacist Funster
    Oct 15, 2013
    1,282
    1,521
    Devon
    Found this on Google Images - hope it helps!
    • Like Like x 3
  6. icantremember
    icantremember Funster
    Sep 2, 2010
    5,340
    7,462
    Nr Watton in Norfolk
    Maz, if it is the engine battery you are after I think you will find it under the floor infront of the passenger seat.
    If you do remove the seats make sure you take no chances with the air bags which are dangerous if set off.
  7. micky drip
    micky drip Read Only Funster
    Jul 4, 2012
    190
    121
    mid wales
    My 2009 fiat doesn't have batteries under front seats, the leisure battery is under rear seat, the van battery is under front floor.
  8. Old Soldier
    Old Soldier
    Apr 10, 2010
    902
    1,483
    Wells in Somerset
    On a similar note, I have a Ducatto, sounds the same. Yes, getting to the battery is not easy..
    On my drivers seat (non swivel) there are two leavers on the left hand side with triangular handles that appear to do nothing when pulled up. They seem to be connected towards front and rear respectively but as I say nothing happens when they are operated. Any ideas?
  9. pappajohn
    Aug 26, 2007
    29,943
    17,608
    YO11 2BD
    Seat adjusters.
    If sat in the seat they do nowt....you need to take SOME weight off the seat and the front or back, depending which lever is pulled (possibly pushed forwards or pulled back) and the seat will raise.
    They are light and flimsy which is why they appear to lift up
    seat slider should be on the front for fore and aft movement.
  10. Abacist
    Abacist Funster
    Oct 15, 2013
    1,282
    1,521
    Devon
    My 2010 seats have a front and rear tilt facility using handles that are on the "outside" of each seat. To tilt back you need to operate the rear lever and push up with your feet and the seat will go back. Similarly by operating the front lever and putting lots of weight on the front of the set it will go down. With both ends pushed down you have lowered the seat and with both up you raise the seat and with either one you have a tilt function for the base of the seat forwards or backwards.
    We run with our seats on the high setting so they need effort to do anything to get them lower. If you run with the seats on the low settings then they will pop up if you use the levers.
    Of course there may be different models of seat and your handles are just blanks that don't do anything.
    • Like Like x 1
  11. Old Soldier
    Old Soldier
    Apr 10, 2010
    902
    1,483
    Wells in Somerset
    Thought that was the case but they don't do anything, even if I'm right off the seat. They seem to only pull upwards but I will try again tomorrow. Thanks.
  12. pappajohn
    Aug 26, 2007
    29,943
    17,608
    YO11 2BD
    Use a torch and, as best as you can, look under the seat to see how and which way they should move.
    they wont be there for show.
    • Like Like x 1
  13. maz
    maz Funster
    Jan 26, 2011
    2,534
    2,173
    Out there somewhere
    Thanks for that, PappaJohn. That's just what I needed to know. :thanks3:
  14. maz
    maz Funster
    Jan 26, 2011
    2,534
    2,173
    Out there somewhere
    Hi Brian. No, it's the leisure batteries I'm after - I know there is one under each cab seat plus one in an external locker. As you say, the engine battery is under the passenger footwell.
    • Like Like x 1
  15. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,346
    34,938
    I do it the other way about to get at the battery under the passenger seat (2003 Ducato).
    I side the seat fully forward to get at the rear bolts then back to take off the front bolts. Replacement is a reversal but I only hand tighten the front bolts to allow adjustment for locating the rear bolts. All four bolts are hex key.
    • Like Like x 1
  16. rangitira
    rangitira Funster
    Jun 30, 2010
    6,374
    13,149
    Cornwall
    Almost sure you will need a #40 star bit, got mine from Halfords, and no! you can buy just the bit, you don't have to buy a complete kit
    • Like Like x 1
  17. smiffy502000
    Aug 5, 2012
    220
    118
    sutton coldfield
    sorry, I cant quite see how it is convenient to have to remove a couple of very heavy seats in order to maintain or replace a battery!
  18. Old Soldier
    Old Soldier
    Apr 10, 2010
    902
    1,483
    Wells in Somerset
    Sorry to say it, but that's all they are there for!! Each one, front and back is sprung loaded and look as if they would have released the angle of the seat as you say but they are not connected to any release mechanism. I suspect that when the base van (Fiat) was converted and they decided to put the leisure battery under the drivers seat there might have been modifications and these leavers were taken out of use. To be fare, we have had Elle over 10 years now and never needed to make any adjustments so a bit late now!! Thanks for trying to help though...::bigsmile:
  19. GJH
    Aug 20, 2007
    27,346
    34,938
    Like many aspects of motorhomes it is a compromise. Having a battery in a locker is convenient for the couple of times a year that it needs to be accessed but it means that the locker can't be used for general storage.
  20. JohnM
    JohnM Read Only Funster
    Nov 8, 2008
    651
    179
    Central Scotland
    Most batteries now are maintenance free, i have one battery under each seat saves a lot of well needed storeage.
