Removing adhesive tape from headlamp proectors (1 Viewer)
Organplayer
110
38
Berkshire
C class
Sept. 1995
Good afternoon everyone. Having just returned from winter in Spain I have removed the adhesive tape from the headlamp protectors and of course the base of the tape is firmly still in place. Sometime ago I think there may well have been advice on this really informative site, giving the answer to this 'problem'. Unfortunately I can't find trace of this information.
Perhaps some kind soul help with the answer.
Eddie.
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
Just cleaned up my headlights a day or so ago.
To get the residue of the sticky tape off I used
" Sticky Stuff Remover " which was purchased
fro Lakeland.
Brisey.
androidGB
363
490
Bristol
Since 2001
fro Lakeland.
Brisey.
Yep, that's at I used as well
Andrew
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
Petrol or white spirit is good, but don't rub too hard as it will dull the plastic.(y)
I'm sure that the purists will disagree....wait for it....:(
Nov 4, 2011
5,920
38,660
Uk
I removed the sticky off my plastic headlights with Meth's on a soft rag.
Aug 4, 2016
608
1,374
Yorkshire
Vantage Neo
Since 2003
Isopropyl alcohol is what I use when removing sign vinyl
O
Organplayer
110
38
Berkshire
C class
Sept. 1995
Thankyou to everyone for your kind information. Off on a tangent, in my teenage years I was a cinema projectionist and acetone,which we acquired from a local chemist shop, we used to join the film with when making up the programme. Much quicker drying than film cement.
Once again many thanks everyone..
Best wishes to us all for a long hot summer.
Ed
Silver-Fox
9,262
28,957
Cheltenham Spa
Rapido
im a not so newbie
I probably wouldn't use acetone on the headlamps bit to aggressive
Panel wipe or stick stuff remover as said previously.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
:rofl: Coarse emery paper. :whistle:
Apr 17, 2017
1,109
3,584
Ferring
Autotrail Cheyenne 840
Since 2017
An angle grinder will work in seconds but one slight drawback with this method is that you will have to replace the headlamps. Hope this helps ;)
Feb 15, 2016
187
235
Lincoln
Hymer T class
WD40 works 99% time with elbow grease
O
Organplayer
110
38
Berkshire
C class
Sept. 1995
Hi Rockcrawler. I tried your suggestion and now I iz drivin wiv only threee fffingaz on mee left hand.
actually did wat a kind member suggested and used WD30 or wuz it 40 or sumfink.
Anyway fanks for you sssuestion.
Ed
Aug 10, 2012
838
891
cambridge
Globecar
since2001
Meths and an car plastic ice scraper
Recommended by the company that make beam benders
They admit they have a problem with long term fitting/ removal
Apr 17, 2017
1,109
3,584
Ferring
Since 2017
Ed I forgot to say wear safety gloves
