Removing a scratch
Discussion in 'Motorhome Chat' started by camocam1, Dec 5, 2014.
  1. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    anyone recommend the best way to remove a fairly deep scratch from external GRP Skin ( damn hedges )
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,912
    23,658
    Narrfoook
    Sadly there is no way to remove a scratch short of changing a panel..
    However............
    A trick I have used to good effect in the past is clear nail varnish, or in some cases I have managed to find a colour of nail varnish so close to the colour it could barely be seen even if you were looking for it.. And yes, lots of different white available !
    • Like it Like it x 1
  3. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    gelcoat repair available on fleabay
  4. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,796
    2,221
    Scotland
    But Jaws option is cheaper. Well he has got loads of nail varnish in many shades on his dressing table!:whistle2::imoutahere:
  5. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,678
    5,879
    Guisborough
  6. funflair
    Dec 11, 2013
    5,678
    5,879
    Guisborough
    could make it worse if not careful.
  7. camocam1
    Aug 28, 2012
    1,112
    783
    Not through to the glasfibre but it noticeable (to me anyway) and would like to try and take out. Used t cut then polish on last van which worked well but it was not GRP Skin
  8. funflair
    Dec 11, 2013
    5,678
    5,879
    Guisborough
    The only way to completely take it out is to flat the whole area down to 1000 grade wet/dry and then polish with cutting compound, BUT you dont know how thick the gel is so dangerous. You could fill it with the same colour and again flat and polish. I would be tempted to just polish with the cutting compound, and I ran a GRP and Carbon Fibre moulding company for 20 years.
    When we made moulds we would double gel so that we had plenty to polish and cut back into.
  9. Silver-Fox
    Silver-Fox Funster
    Sep 5, 2014
    1,026
    1,599
    Cheltenham Spa
    Is it colour GRP or has it had a coat of paint over it
    As said above try a fine cutting compound, you could even try some good old brasso but dont go heavy with it incase you break through and end up with a patch :eek:
  10. camocam1
    Aug 28, 2012
    1,112
    783
    Thanks guys
    Think it is painted as contacted Bailley and they said would need to be re painted
    Will try just giving it a light rub with T Cut or similar then autoglem resin Polish and see if can get the worst of the scratch out
  11. Silver-Fox
    Silver-Fox Funster
    Sep 5, 2014
    1,026
    1,599
    Cheltenham Spa
    If its modern paint it will be water based paint with a clear coat top coat
    Good luck, if you use Autoglym SRP it has lots of fillers in it and will hide the scratch up to a point.
  12. Jaws
    Sep 26, 2008
    18,912
    23,658
    Narrfoook
    You been looking ??? :D
    Yup.. had a chap who used a gel coat repair kit.. Took me over a day to sort the mess out and a LOT of hard work !
