remove tent fabric around bed above cab hymer
Discussion in 'The Beginner' started by 1948, Mar 9, 2010.
  1. 1948
    1948 Read Only Funster
    Dec 3, 2009
    444
    46
    surrey
    can anyone please advise how to detach the tent fabric, around the cab bed in a Hymer, It looks dirty and stained Mrs would like to wash it. The bottom edge detached easily but top edge is a continous strip fixed to the main cab body. Any advice very much appreciated.
    Thanks for reading
  2. Loujess
    Loujess Read Only Funster
    Jan 10, 2010
    3,261
    3,168
    Leeds UK
    I had a Hymer but I'm a bit confused. I don't understand what you mean by tent fabric around the cab bed. Do you mean the luton, the bed above the cab? We never had tent fabric.
    Ivy
  3. 1948
    Dec 3, 2009
    444
    46
    surrey
    the hymer we acquired 2 weeks ago got a double bed above the cab seats which drops down . When it is in the dropped position, there is fabric which encloses 3/4 of the bed (like a tent)
  4. jaygee
    jaygee Funster
    Mar 21, 2009
    1,182
    739
    Harwich, Essex
    Presume you mean the curtains that draw round to cover the windows?
    If it is these then they are on curtain hooks and you just unhook them. If you mean the more solid fabric at each side I don't think these are detatchable?
  5. 1948
    Dec 3, 2009
    444
    46
    surrey
    we only refer to the frabic/netting which encloses the dorp down bed above cab seats, not the ones around windows
  6. John H
    John H Read Only Funster
    Sep 2, 2009
    254
    24
    Anglesey
    If they can't be removed you could always ask your local car valeter to clean them in situ.
    John
  7. JAY KAY
    JAY KAY Read Only Funster
    Aug 22, 2007
    24
    Shotgate, Essex
    Hiya 1948
    I assume you have taken the mattress out of the pull down bed, this will expose the screws that hold the "Turin shroud" to the base.
    The top of the shroud is also held bt a series of scews which have plastic caps over them, the shroud can now be taken out for washing, a replacement from Hymer is as you can imagine is costly to say the least ours needed replacing so cruise control made a new one using cutain lining material and some knicker elastic works a treat.
    John D
  8. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,928
    1,947
    Warwickshire
    Depends what year it is, but on ours, the bottom is held by plastic tracks that slot into a matching track - easier to see with the mattress removed. The tracks are not continuous but comprise a series of strategically located units. If I remember correctly, the top uses either a continuous track, which just pulls out, or screws - or possibly a combination of both. If you're still stuck, post again in the morning and I'll go and have a look - it's too late now.
    Philip
    p.s. ours is 2003 vintage.
  9. dragabed
    dragabed Read Only Funster
    Apr 15, 2009
    63
    http://www.motorhomefun.co.uk/how-do-i/21361-remove-tent-fabric-around-bed-above-cab-
    ours is as jay kay described took them out to wash more diff putting back in same screw holes
  10. JackieP
    JackieP Funster
    Mar 10, 2010
    286
    704
    Isle of Man
    I have an 1984 Hymer and once removed the fabric for cleaning. As other have said, the bottom screws are under the mattress and the top screws are revealed by removing the vinyl covered strip at the top and bottom of the bed. It is fiddly to get the screws back in at the top but it can be done.
    I ended up doing away with the whole 'tent' thing. I made new curtains for our van and velcroed a plain valance around the front and sides of the bed. With the front curtains drawn, the whole bed is enclosed and, if you're lucky enough to be somewhere with no neighbours, it's lovely to lie in bed in the morning and see outside.
    I don't know if you have that huge shelf thing over your bed, but I removed that too - made life a lot easier and gave us so much more room up there.
  11. 1948
    Dec 3, 2009
    444
    46
    surrey
    lifted one end of the male plastic and pulled the whole thing out all in one go think putting it back after wash another question later thanks for all your replies
Similar Threads
  1. giovanni
    22
    623
  2. Birtha
    196
  3. Alan-2016
    299
  4. Gillus
    43
    2,496
  5. SwissBob
    7
    651
