Remove & Replace Front Pads on 2.8JTD
Discussion in 'Motorhome Chat' started by estcres, Aug 30, 2010.
  1. estcres
    estcres Read Only Funster
    Oct 9, 2007
    1,301
    766
    Sunny Bournemouth
    Hi,
    Can anyone advise me how easy it is to change the front pads on my 2.8JTD Ducato.
    I have been told that there are 2 bolts which have to be loosened, the bottom one removed totally and the caliper hinges on the top bolt.
    Swing the caliper upwards and remove the old pads, fit the new replacements and using a G clamp push the piston back into the caliper.
    This is how I've been told to do it, is this procedure correct?
    Once fully pushed back you can return the caliper to the disc and replace the bottom bolt and tighten them both up.
  2. Glynn
    Glynn Read Only Funster
    May 2, 2010
    163
    18
    Lancashire
    Yes more or less, but don't forget to put copperslip grease on the backs of the new pads.
  3. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    Don't forget to take the top off your master cylinder before you start.....pump the brakes when you've finished and put the top back on....pour some hot/warm soapy water over any brake fluid spillage.
  4. patr
    patr Read Only Funster
    Jul 1, 2008
    92
    Mid Wales
    As above but don't forget that on each side there is an electrical connector for the wear indicator and if you do use a g-clamp to push the caliper pistons in, put a thin piece of plywood or similar over the piston to protect it and spread the pressure. Note which side of the disc the wired pad goes before removal.
    Plus if you have access to an air compressor give the caliper a good blow over or, failing that, get a stiff non-metallic brush and get as much crud and brake dust out.
    I now ensure that I do this prior to putting copper grease on the pad backs and the piston surface:RollEyes:
  5. jaygee
    jaygee Funster
    Mar 21, 2009
    1,177
    738
    Harwich, Essex
    you are working on the brakes,FRONT BRAKES,if your not sure about what your doing take it to someone that does.it wont cost much to get fitted but may save more than a few pounds.
    I have my own garage buisness and have seen the results of incorrectly fitted pads.
    example when winding back caliper piston open bleed valve or can turn over seal in master cyl
    Copper grease is still wildly used but not ideal.and in some instances not recommended
    DONT blow out brake dust with airline
    Just a few does and donts
    Sorry if seems a heavy post but just concerned
    Regards
    Tony
  6. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,154
    13,979
    Heavan
    Having done mine recently (check earlier posts or my blog) I whole heartedly agree. I have changed numerous pads and in essence the job is quite easy. However the discs are prone to warping and fade which mine did, I could not check properly as I did not have a geomatary tool, end results was the pads rubbed, got very hot, and kept burning. Ended up getting my reliable garage to take a look whom then had to replace pads, and discs.
    I sort of knew what I was doing, but stopping 4t down alpine roads like we use and a bit of condensation in the brakes when standing for long periods does alter the ball game slightly or it did with me.
