Remote light control
Discussion in 'Tech/Mech General' started by Regallee, Jul 31, 2013.
  1. Regallee
    Regallee Read Only Funster
    Jul 28, 2013
    7
    Stoke
    Hi. I would like to fit a remote light control to my ceiling light in my van, save rummaging around when returning in the dark. Have got the unit of eBay, but would still like to be able to use the switches in the van. My question is would a 5 pin relay be the best way to have 2 supplies to one light or is it possible to use diodes to prevent back flow down the other supply? Not sure if I made that clear but any advice on this would be appreciated. Thanks.
  2. hilldweller
    Dec 5, 2008
    26,909
    25,760
    Macclesfield
    Just wire a single pole relay across the existing switch. Either turn it on, both must be off.
  3. Regallee
    Jul 28, 2013
    7
    Stoke
  4. Dubiousp
    Dubiousp Read Only Funster
    Jul 3, 2012
    233
    45
    Hampshire
    • Like Like x 1
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,374
    9,819
    the relay would introduce a current drain on the battery when off hookup so it would be best to convert the circuit to 2 way switching if the remote switch allows this
  6. Dubiousp
    Jul 3, 2012
    233
    45
    Hampshire
    Certainly would unless you go solid state even then draw is still there unless use a low draw relay in its quiesent state
    Or go to the range or cost co they are doing remote led downloghts cheap at mo, leave one under the shelf somewhere
