Remapping for a Fiat 2.5td
Discussion in 'Tech/Mech General' started by andyframpton, Nov 13, 2008.
  1. andyframpton
    andyframpton Read Only Funster
    Jun 18, 2008
    13
    Bristol
    Hi Guys
    My 1995 Ducato could do will a load more umphfff can any one tell me where is is best place around Bristol to get it remapped and some sort of cost?
    Does anyone have any good or bad points i should be looking out for?:thumb:
    cheers
    Andy:Laughing:
  2. Braunston
    Braunston Read Only Funster
    May 21, 2008
    1,415
    7
    Hi,
    I'm not sure the Fiat 2.5 TD, if that is the engine that you have, can be remapped or have a smartbox fitted as if i am correct the 2.5 TD Ducato was/is a normal type diesel i.e. has a mechanical pump and mechanical injectors as against the Fiat JTD engine which has electronic injectors and pump which are controlled by a ECU.
    To remap or fit a smartbox etc the engine needs to be electronically controlled as it is the electronics that are altered in remapping or the fitting of a smartbox
    Hope that makes sense
  3. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,568
    3,375
    Telford, Shropshire
    Braunston is absolutely correct, the 2.5 diesel lump is of the traditional type with a mechanical injector pump and therefore cannot be remapped. The best you could hope for is to have the pump timing and fuelling optimised by a diesel specialist and possibly having an intercooler fitted if there isn't already one on the van.
    D.
    In edit: I just re-read your original post and notice that you don't day it is a turbo unit anyway, if it hasn't already got a turbo then the addition of one will make a huge difference.
