Relay Box ID required Please.
Discussion in 'Tech/Mech General' started by Tootles, Jul 1, 2014.
  1. Tootles
    Tootles Funster
    Sep 14, 2013
    9,136
    32,626
    Lancaster
    This unit is located under the passenger seat on our LHD 1991 Hymer Camp, but has nothing to do with the base unit, only the habitation. No 1 lead, (pictured) runs direct to the hab battery positive. N0 2 lead runs off into the main loom, and is not an add-on. No 3 & 4 leads run also off into the original habitation side loom. It is obviously a relay, but it's rated at 35 Amps (at 12 volts)! The main habitation supply cable, coloured red, also leads from the battery, so this unit is not for the main supply to the rear. It feeds SOMETHING, as wires 4 & 5 must be the switching side, but what??? If it was an add-on, then the cables would be separate from the main loom bundle, so therefore it must have been fitted from new, (maybe by customer request?) I have no idea at all......Possibly an old supply to a 12 volt telly????
    Any ideas most welcome.
    Dave.
  2. SuperMike
    SuperMike Funster
    Apr 28, 2010
    1,013
    1,133
    St Albans
    Disconnect No.1 lead and see what stops working. :rofl:
    • Like Like x 1
  3. Whatton
    Whatton Read Only Funster
    Apr 30, 2009
    96
    82
    Nottinghamshire
    Is it the fridge relay that turns off the 12V supply to the fridge when the engine stops running? If 3+4 are only live when the engines running then 1+2 could be the 12V feed to the fridge.
    • Like Like x 1
  4. Tootles
    Tootles Funster
    Sep 14, 2013
    9,136
    32,626
    Lancaster
    Great idea, and thanks! I will disconnect 3, ( and 4), then see if the fridge dosent work when the engine is running. (y)(y)
    I didnt think of the fridge, as I assumed that it ran from the vehicle battery, switching off from 12 volt to stop the battery being killed during long stops.
