Reich taps.
Discussion in 'Tech/Mech General' started by elamessa, Aug 2, 2015.
  1. elamessa
    elamessa Funster
    May 20, 2009
    493
    469
    Haute Vienne, France
    Have a slight leak from base of kitchen tap and on closer inspection noticed a small crack in the main body.
    Wondereing how difficult they are to change or is it dealer only job?
    Cheers.
  2. trevorf
    trevorf Funster
    Feb 19, 2014
    57
    94
    Cheshire
    Every make and model will have slightly different access and space under the sink. Not difficult as long as you can lie upside down under the kitchen sink and reach up with a tap spanner. Connections are usually just a "push fit"
    • Like Like x 1
  3. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,636
    3,188
    Cumbria
    If it's a lever mixer tap, prise out the blue and red plastic indicators and undo the screw. The top should pull off, you should see a brass threaded locking ring that it's worth trying to tighten down a bit more. In my experience, a slight crack in the tap body shouldn't cause a leak, but if there's not enough clamping pressure on the cartridge inside the tap, it will cause a leak which would manifest itself at the crack in the body. Mine did similar after frost expanded the components apart, then left them loose once the frost melted. Worth a try before lashing out on a new tap assembly.
  4. elamessa
    elamessa Funster
    May 20, 2009
    493
    469
    Thanks for the above,
    Unfortunately not able to tighten so have ordered new mixer. Will then have to see how easy it is to change, although dont look so bad from this picture. Are they push fit or screw thread? 20150802_120101.jpg
  5. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,525
    5,617
    West Sussex
    They are ferral connections you will have to cut the pipe & refit the pipes to the new tap with Jubilee clips.
  6. matamoros
    matamoros Funster
    May 15, 2008
    2,333
    3,521
    Ex Rochdale now Tavira, S. Brittany & Europe
    I had a problem with a reich tap/shower unit on a caravan and attempted to do it myself, even bought a special sink spanner, but gave up because of restricted access and tightness, I got a man in.
    From what I remember the connections are push in but secured with a rod that has to be pushed out, but they may not all be the same.
    I would suggest waiting to see what the new part is like before dismantling the old one.
  7. Poohbear
    Poohbear Funster
    May 18, 2015
    269
    428
    Worcester
    Yes watch those ferral connections, they can be quite dangerous :)
    • Like Like x 2
  8. teensvan99
    teensvan99 Funster
    May 17, 2015
    226
    244
    Margate
    The best way to see if you are able to change the tap is remove the sink first. This gives you a much better chance to see if you are up to the job. It took me an hour and half to remove the sink and waste tighten tap base and put all back the other day. The reich taps do have silly little pins you have to remove to get connections out. Or they did on the one I changed in our old Burstner. Better to DIY and you then know next time if it goes wrong how it works.
    steve & ann. -------- teensvan
  9. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,636
    3,188
    Cumbria
    Sorry, been away from the pc for a couple of days. If you undo that big brass nut in the photo, the tap will pull away from the sink. You may want to snip through the brown and blue microswitch wires (power off first) and reconnect the new wires with a chocolate block connector. If you look at where the two pipes enter the base of the tap, you'll see a little black plastic pin between them, push this out and then the pipes can be detached by pulling them away from the tap body, remember to make a note of which way round the hot and cold are fitted. Refit by reversing the procedure.
    • Like Like x 2
  10. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    Be sure to order the correct diameter replacement as the two sizes look alike in pictures on the web.
  11. elamessa
    elamessa Funster
    May 20, 2009
    493
    469
    Ordered from www.leader-loisers.com and the diagram of the one I ordered is exactly the same as the one im replacing. They have a good returns policy if its wrong.
  12. Techno
    Jul 28, 2010
    14,182
    14,954
    I vaguely recall 27mm & 33mm
  13. elamessa
    elamessa Funster
    May 20, 2009
    493
    469
    [​IMG]
    • Like Like x 1
  14. Techno
    Jul 28, 2010
    14,182
    14,954
    Yes 27 / 33 (y)
    • Like Like x 1
  15. Manic
    Manic Funster
    Nov 4, 2011
    902
    1,040
    Uk
    Rather than cut the pipes, undo the nut and pull the tap up through the hole and you should see a dowel pin between the pipes, push this out and the pipes should pull out of the tap base.
    • Like Like x 1
  16. elamessa
    elamessa Funster
    May 20, 2009
    493
    469
    Reich tap arrived this morning 20 mins later installed in place of leaking one. Apart from the pin on the old one being white and not very easy to see it was a straight forward job.
    Tools required. Wrench, wire cutters, solder and iron and cable ties oh and wife for holding things especially wires whilst I soldered them
    Big thanks to funsters for advice.
    (y):)
    • Like Like x 3
