Supertramp
Once again I turn to you wonderful funsters for assistance. I wasn't sure whether to post this in my other thread but it's a new topic, I do apologise if this isn't correct.
I've just had a 100w panel installed with a phocos CML regulator (I'm in Morocco). Using the multimeter the battery showed 14v/13.9v yesterday in the sun.
Overnight however the regulator started beeping. It turns out it beeps each time the state of battery charge drops, and 5 beeps when it gets to 10% then 25 beeps which means the load will shut off.
This was at 2:30am, despite leaving th hookup (ctek charged) at 12pm that afternoon, having 14v solar and driving some miles. I was ready to throw the battery but checked the voltage and it said 12.4v, so around 80% correct? Yet the regulator battery indicator lit up the bulb that means less than 10% and eventually discharged.
Then I noticed a pattern that this happens each time my compressor fridge kicks in, the 25 beeps come (meaning shut down). Obviously at this happened in the early hours I was conscious of the noise so I'm drastically trying to sort it today.
The Waeco is connected directly to the battery so I'm wondering if the regulator is getting in a tizzy?
It's been happening today too despite the battery showing 12.75v, compressor kicks in, regulator light turns red to show deep discharge and 25 beeps.
Also, does it matter if there is no load coming from the regulator? That space is empty.
If the regulator is kaput, what do people recommend? I can see it's clearly charging the battery, but the indicator lights aren't showing this and the acoustic warning is driving me mad.
Help! Thank you !!
Help! Thank you !!
