Refillable Propane Cylinders
Discussion in 'Motorhome Accessories' started by Blodwyn Pig, Jul 25, 2013.
  1. Blodwyn Pig
    Blodwyn Pig Read Only Funster
    Oct 1, 2012
    97
    26
    Derbyshire
    Hi there, thinking about fitting two 6 kg refillable gas cylinders in the motorhome but which is the best?
    Gaslow, Autogas 2000, Gasit or is there another?
    An exterior tank is not really an option on our Autoquest 180.
    Thanks.
    Mike. :BigGrin:
    • Like Like x 1
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,217
    7,338
    Nr Watton in Norfolk
    Why do you say an external tank is not an option?
    We have a very low chassis and had an underslung tank fitted by Autogas2000 (brilliant service) which apart from the convenience of topping up with gas any time it has also freed up the old gas locker for additional storage.
    • Like Like x 1
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,337
    34,822
    When we had an Autoquest 100 we rejected the idea of two 6Kg fixed bottles as it would have been very expensive and only heavy steel bottles were available. We were considering a fixed tank when the van was written off.
    If I were you I would look into having an underfloor tank fitted. There should be adequate depth as there already will be for the fuel tank and grey waste tank.
  4. Blodwyn Pig
    Oct 1, 2012
    97
    26
    Derbyshire
    Thanks for the replies. Didn't think there would be enough room for under slung tank so may have to go away and have a rethink :thumb:
  5. icantremember
    Sep 2, 2010
    5,217
    7,338
    Probably worth a visit to see Chris at Autogas2000 near Thirsk. He has all shapes and sizes of lpg tanks along loads of experience and good ideas.
    Of course he also does refillable bottles ...... I have no connection with Autogas2000 except being a satisfied customer but I would be open to any commission payments should they appear.:Wink:
  6. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,449
    Stokesley, North Yorks
    I had my two 11kg bottles fitted by Chris and Co at Autogas 2000.
    Originally I had wanted an underslung tank, but when they had a look they said that the available space would only give me about the same amount of gas as the two bottles, but for a lot more expense. They could have taken my money and fit underslung but chose to give me good advice instead.
    First class service and honest service :thumb:
    Actually just been and filled up lpg for the first time since having the system fitted.
    Only used one bottle, which was not quite empty.
    Total cost was £13.57p.
  7. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,759
    3,258
    Eastbourne East Sussex
    All the bottles are pretty similar, Alugas and I think Gasit are Aluminium and lighter than the steel ones. Gaslow are a pretty colour if that's what you like.
  8. GJH
    Aug 20, 2007
    27,337
    34,822
    Gasit are steel according to their web site. I think Alugas are the only aluminium ones.
  9. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    bp and cepsa do see through bottles so you can see how much you are putting in .
  10. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    IMHO gasit are cheapest and apart from the colour identical to gaslow lightest and most expensive alugas bottles.
    easy to self fit if you can use basic hand tools:thumb:
  11. ramsthom
    ramsthom Funster
    Nov 23, 2011
    144
    89
    durham
    Just had 2x6kg refillable cylinders fitted at Autogas 2000 near Thirsk. Excellent service and price. I believe the 6 kg cylinders only available in steel. The larger cylinders are available in aluminium. You also get a 5% MHF discount - membership number required.
