refillable gas bottles from garages
Discussion in 'Motorhome Chat' started by movan, Mar 23, 2014.
  1. movan
    movan Funster Life Member
    Dec 2, 2009
    13,973
    25,431
    Moving around
    apparently there is quite a high saving in having the gas bottles that you fill from a garage forecourt...... can you tell me in simple terms please how converting to this works? Does the refillable bottle go in the same place as the existing orange bottle? (I keep seeing posts about can I put them under the van, etc.). How much does it cost to convert and so roughly I can work out if it would be cheaper or not. Is there any chance that in the near future it will be impossible to find garages that provide this gas?
    I know some of these questions will probably be stupid but totally confused about it all and looking for money saving ideas. Thank you.
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    You can have the refillable bottles fitted in the gas locker or have an underslung tank fitted and leave the locker free for other stuff. I think your locker will take two 11Kg Alugas bottles the same as ours.
    Prices vary depending on what you want doing and it will be a few hundred. Whether you will recoup that in savings on gas depends on usage but you have the convenience of not having to change bottles and can top up any time, not just when the bottle is empty.
    With so many vehicles running on Autogas these days it's unlikely that it will be impossible to obtain it in future.
    Have a word with Dave Newell, he'll give you good advice.
    • Like it Like it x 1
  3. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,288
    16,960
    Liverpool.
    It depends on how much you use the van. You would need to use a lot of gas before it became cost effective. Most have refillable bottles for convenience, to save the trouble abroad changing bottles and regulators.
  4. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,455
    25,485
    Planet Zog
    Good morning Joy,
    Others will come in here and talk about the various systems with a great deal more knowledge than I could ever have, but basically there are three ways:
    1) refillable "calor" type bottles which you have to exchange which I assume is what you have now. Gas is expensive but that is the only cost assuming you already have bottles
    2) A "Gaslow" type system where the bottles are able to be refilled in situ with the required 80% cut off. This requires special bottles and also a refilling point. Gas is same as autogas you see on forecourts but the bottles are pricey to buy and the various hoses and fixed refill adaptor ("plug" in side of van skirting) is also expensive
    3) A fixed underslung system. Permanent bottle with refill point as per Gaslow. Once again gas is cheap but buying and fitting is expensive.
    Conclusion is that unless you are a very heavy gas user or really like the convenience (I have option 3 and it is brilliant) against the high initial costs then you really are better sticking with the option (1) as over a period of time it is the most economical. Hope that helps a bit. Cheers, David
    • Like it Like it x 3
  5. Langtoftlad
    Langtoftlad Funster Life Member
    Apr 12, 2011
    1,942
    4,965
    Langtoft, South Lincs
    At Newark, I was browsing the WildAx Aurora, and that comes with a refillable lpg as standard - 22 litres which I presume is the equivalent of an 11kg standard bottle ???
    My Q is do these tanks have reliable gauges because without a second bottle to switch over to, how do you know when you're about to run out?
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    The other option of course is a gas refill adapter:hardhat::hardhat::hardhat:
    I used one for years until I got a van with a fixed tank.
    The bigger advantage for some is that alugas bottles are very light so free up some payload.
    Easy to fill up abroad with a refillable bottle providing you have a set of or the correct adapter. LPG is around half the price of an exchange bottle.
    It all depends how much gas you use. (Remember if you do get LPG you can ask for the lower rate of VAT 5% instead of 25% [you won't always get it mind, shop assistants cannot do sums so I'm told])
  7. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,720
    23,115
    Narrfoook
    No one has mentioned the cost of the gas.. I understand a 13k bottle is around the £23 mark now ( though I really have no idea )
    With refillables, the cost of the same amount of gas costs ABOUT £14.90 ( cost depends on garage price as it varies quite a bit )
    If you go for a stand alone refillable bottle you can always sell it when you are finished with it, thereby making a considerable saving over the years ( almost £10 per fill, plus not having to drive around to exchange a bottle as there are MANY garages that have LPG pumps nowadays ) plus getting approx 2/3rds of the cost of the bottle back when you sell it second hand at the end of your use, something an awful lot of people seem to miss out on or simple do not consider
    • Like it Like it x 2
  8. movan
    Dec 2, 2009
    13,973
    25,431
    Moving around
    Thanks everyone.
    Langto, I don't know the answer but when I was at a show with Maz I am sure she was talking abaout changing the top on hers to one which has a little round thing that shows how much gas is left in the bottle so you need never run out because you fill up as and when you want to. If she sees this thread I am sure she will be able to help you.:thumb::thumb:
    Back to original question, when saying can cost 'quite alot of money' can we say roughly how much please?
  9. GJH
    Aug 20, 2007
    27,349
    34,968
    The gauges on our Alugas bottles read full (or fullish) until they are half empty at which time the needle drops to half. There is a similar drop when the bottle is nearly empty but when it first reads empty there is (I think) 6 litres left.
    As you don't have to wait until the bottle is empty to refill, though, it is normally convenient to top up when you happen to pass a garage selling autogas.
  10. chaser
    chaser Funster
    Feb 16, 2013
    7,710
    8,779
    uttoxeter
    The bottle will cost you about £170 to fit yourself or someone who can DIY , it's not complicated other than screwing pipes on, little different than connecting your pipe to the bottle you have now, then your gas is about half price:thumb:
  11. scotjimland
    Jul 25, 2007
    28,939
    25,628
  12. CazPaul
    CazPaul Read Only Funster
    Jun 30, 2011
    290
    166
    Durham
    Good point about underslung tanks that if you sell then it goes with the motorhome, best to have refillable bottles then you can remove easy. A lot depends on usage and storage, underslung frees up the gas locker.
    So how much gas do you use, how long do you intend keeping the MH, what appliances run on gas and how much storage do you have.
    MH's with diesel heating can get away with a small refillable bottle.
    Paul.
  13. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,923
    1,944
    Warwickshire
    As others have said, the refillable option is mainly about convenience rather than cost saving, although if you are a very heavy lpg user, the capital cost will be recovered more quickly. You can improve the return too by getting an account with some lpg suppliers that carries 5% VAT rather than 20%. But for that, you will have to accept some geographical restrictions, since I am not aware of a national supplier that offers that VAT facility.
    Why not have a chat to Autogas in Thirsk (sponsored link on the right of MHF and their website contains some useful descriptions about installations) or talk to two respected trade funsters, both of whom offer discounts: Vanbitz in Taunton and Dave Newell in Telford. There may be others but these two spring to mind.
  14. chaser
    chaser Funster
    Feb 16, 2013
    7,710
    8,779
    uttoxeter
  15. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,759
    10,175
  16. scotjimland
    Jul 25, 2007
    28,939
    25,628
    Yes that's a good bit cheaper than Gaslow..
    but you have to add in filling hose and filter + extra for a white filling point .. makes it £188.93
    still a good saving :thumb:
  17. welshgary
    welshgary Funster
    Sep 28, 2013
    21
    Bridgend, South Wales
    Gasit System
    Hi I'm a relatively Newbie, but as I intend to travel Europe, was concerned about the various bottles, regulators etc, so opted for a refillable system. I obtained this by courier from Gasit, which was an 11kg & a 6kg bottle, which fit easily into my locker. I have the refill valve in the locker, together with an automatic changeover valve, all hoses, new regulator plus all 3 continental screw in adaptors. I fitted this system myself, only problem was I used PTFE tape on all joints, which I should not have done. The total cost was approx £400, which will take a while to recoup, but it's so easy to top up. Hope this helps.
  18. Jaws
    Sep 26, 2008
    18,720
    23,115
    Narrfoook
    Hacccctttuuullay
    There are full Gasit kits available now for £161.
    Kit is supplied with the bits needed :thumb:
  19. scotjimland
    Jul 25, 2007
    28,939
    25,628
    yes I was are aware of that ..YOUR price is 'in locker' filling.. and without a filter.
    mine at £188.93 was for the remote fill point.
  20. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
