Refillable gas - back up canister on continent (RFG Q2)
Discussion in 'Motorhome Accessories' started by Soozywoozy, Apr 26, 2014.
  1. Soozywoozy
    Soozywoozy Funster
    Feb 18, 2014
    464
    416
    Oxfordshire - edge of the cotswolds
    Seriously considering refillable gas and hopefully opting for alugas ( see other thread) however not sure need 2 canisters as can refill quite regularly and outlay cost of 2 a bit too much at moment.
    main worry is when we go skiing will possibly need more than one and tank access to LPG without moving off "mountain" and loosing camper spot not a good option
    Therefore thinking of doing 2 things
    1) taking small calor with us just as back up
    2) buying in France small canister - I believe its a lot cheaper
    How feasible is this and how easy is it to swap between the systems - I know I have to get continental fillers anyway, but what about internal connectors?
  2. sadlonelygit
    sadlonelygit Read Only Funster
    Jan 28, 2014
    155
    95
    forest of dean
    you need to know how long you're staying on site, what your gas consumption is and how much you're carrying.
    i doubt you will get more than 3 weeks in winter with 2 x 11kgs, and the 4.5kg campinggaz cylinders are frighteningly expensive, so perhaps a little drive out might be called for.
  3. Forestboy
    Forestboy Funster Life Member
    Jul 31, 2007
    5,086
    8,178
    Forest of Dean
    We ski every year and have twin Alugas 44 litres which we fill at the bottom of the mountain before heading up and we always carry a spare 13kg propane as well. Gas consumption depends a lot on the temperature and the thermal quality of you van. Remember at night in a ski resort it can drop to minus 20 or more and heating needs to be left on 24 hrs. We usually stay up for 7 days use all our on-board facilities and we also cook in our oven have never used the spare yet but our van is exceptionally well insulated. We've seen others run out and have to make that long journey down after 4 days so don't scrimp.
  4. Soozywoozy
    Soozywoozy Funster
    Feb 18, 2014
    464
    416
    Alas only 7-10 days skiing available and hoping to stay on sites with Ehu so will need gas for heating/ limited cooking. Have a new truma system which can use electric/ gas combo or gas or electric. Therefore instead of shelling out for additional alugas cylinder may not need I was looking at practicality of additional calor (which already own) buying straight from France gas bottle and the ease of swapping between systems
  5. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,864
    1,915
    Warwickshire
    If you can stretch to a twin 11 kg setup I would recommend it. We have used a full 11 kg bottle in three days - and that was in Derbyshire one very cold New Year. Regarding not moving off pitch, you can get a Gaslow adapter and pipe that allows you to plug in a free-standing bottle to the refillable input point. Useful for those who need to carry an emergency Calor-type bottle as well as the refillables.
  6. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,842
    3,341
    Eastbourne East Sussex
    If you are going to have ehu, then use it for some heating. A fan heater on its lowest setting will save huge amounts of gas.
  7. missbusybusy
    missbusybusy Read Only Funster
    Nov 27, 2011
    93
    36
    Northampton
    we use an adaptor (we have a couple of different ones) to connect an external outside bottle to the refillable system when required, it works a treat :BigGrin:
