red bottle lpg? (1 Viewer)
dogmanlpool
98
37
liverpool
mercedes 609d
hello as anyone yet tried this new adaptor off ebay ? that you use to fill empty gas bottles at the LPG pump at the petrol station ? thanks keith
Sep 23, 2007
1,710
1,970
Leicestershire
4 and many as a tugger
It has been discissed on here somewhere, I will look for the thread.
There will be some folks running for cover at the very thought.
Link Removed
Andy
43,319
49,393
found this in one of the threads...
t you must make sure the bottle is empty before refilling, otherwise it could be over 80%. It also means a gas bottle wont be tested during it's life if it's constantly refilled without going back to the issued company.
Gaslow acieve this automatically and the RV tanks have a bleed valve so you can check the 80% level.
so when it comes to testing how do you go on with a gaslow bottle.
calor may test a selection of bottles but you dont return your gaslow for filling/ testing......
how many gaslow users return their bottle once in a while for testing ?
probably none :RollEyes:
scotjimland
2,303
9,960
A Woosh bang
Ohh dear .. :Doh:
I have a gut feeling we're in for a long discussion with our new 'Facts friends'
:roflmto::roflmto:
lebesset
760
you have to realise that gas bottles are only used at a very low pressure approx 10 bar , about the same as a truck tyre made of rubber and fabric .....that's why you can now have plastic ones !
they in fact have to be able to operated at 15 bar .....and their test pressure [ don't know about the plastic ones ] is 30 bar !
so don't worry about it too much ; I have had a lpg tank on a vehicle inspected at 30 years old ....good as new
a couple have of times I have been permitted into a gas bottle refilling plant ; one thing they had in common was ...no inspection at all ; no doubt if they were obviously bent or the paint was non existant they would get put on one side , but I didn't actually see that happen
some years ago there was a camp site just north of vinaroz , if you approached from the north you had to make a spanish left ; a british first timer in a hymer A class wanted to go there and just made a standard left ....tragically a van approaching from the other direction didn't realise he was going to make an illegal turn which was also too late , and T boned him on the gas bottle ; both passengers in the van were killed ...the bottle was severely squashed but it didn't even leak ; that's strong
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I N C O M I N G !
A regular on all forums and it doesn't half stir 'em on the safety issues.
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
The only bottle I would ever consider filling is the BP gaslite - you can actually see the gas level inside and you could mark the safe level for future use - maybe I am a coward but I dont like things that go bang and I saw an Oxygen bottle blow once - not a pretty sight:ROFLMAO:
lebesset
760
you are comparing apples and pears , lpg is low pressure and oxygen is high pressure
and personally I would rather trust an officially approved and tested lpg pump than a line on a bottle ; I know it means you need to know your 2 times table but I can still cope with that personally
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
But where would you get an adapter? They look like the butane type connection.:cry:
If they were available then I'd love to use one and then I'd only need to carry 1 bottle most of the time.
haganap
12,758
26,438
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Q THE WILDMAN:ROFLMAO:
But remember not all members have been posting for a long time.
heres my two pence worth,, get a gaslow, morre dosh but worth the hassle/
scotjimland
2,303
9,960
A Woosh bang
from an other thread: posted by Landy lover
Try Gaslow - home product codes 01-1673 and 01-1673T both these are high pressure adaptors to fit BP gaslite the thread should screw on to UK standard Butane worth buying a bag or two of the spare sealing washers at the same time they do not last too long when being reused. The fitting clips on to the top of the cylinder and the lever opens the valve in the top of the bottle. Most caravan/motorhome outlets stock these now.
just checked , you would also need a Propane to Butane adapter
jim
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
jim
Yes Jim, that's the problem and I'd love to find a way around it.:Sad:
I don't think there is an on off valve on the bottle and I'm not sure that you'd be able to fill it through the valve on the butane type connector. Problems problems, I'll just have to stick to blowing up vans and filling stations I guess!
scotjimland
2,303
9,960
A Woosh bang
Derek .. check this Gaslow product No 01-4330
would this plus the bottle adapter not do the job ?
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
Propane to Gaslow Jim, propane to butane is what I think is needed.
Assuming of course that the B.P. gaslight is using a standard butane regulator.
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
:thumb:
The valve is in the bottle fitting and is operated by the Gaslow Fitting - The fitting has a lever on the back that has three positions - horizontal is off - vertical is on - horizontal and push in is to remove the fitting - Gaslow do a range of stainless steel pipes and adaptors to suit most needs all have the 'Butane' end which fits all there bottle adaptors and there is a range of other adaptors to suit for the other end - personally I think their quality and adapability is fantastic.:thumb:
Thanks JIm - save me a lot of writing :thumb::thumb:
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
I have a spare butane pigtail so all I would need is my adapter and something to accept a propane male leading into a butane connector. The gaslow connector would suit if they could be connected somehow. :helpsos:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
HASSEL?????? HEARD/ read LOTS OF POSTS ABOUT LEAKING GASLOW pigtails etc,:Eeek::whatthe::Eeek: never seen any on the filling adapter leaking :thumb::ROFLMAO::ROFLMAO::ROFLMAO:
terry
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
This will run as long as the 'gassing on aires' does!!!
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Totally agree but have you been near a lorry tyre at 110 psi when it goes bang - it still hurts - anyone filling a container with a pressurised liquid that gasses needs to be aware that there is some considerable danger attached to that especially when using what is in effect unapproved systems that could affect their insurance in event of a disaster . Having said that everyone has to assess their own needs and risks IMO the risk of filling a bottle that has no means of accurately assessing the 80% fill is unacceptable filling one that you can assess is perfectly acceptable hence my suggestion that the BP Gaslite bottle which allows you to see the fluid level is a good option.
43,319
49,393
Totally agree landy,
when you first 'buy' a new 'gaslight' bottle simply mark the level with a permenant marker pen and just refill to that level and no more.
cant go far wrong then.
43,319
49,393
i'v never filled anything with lpg but i thought it was a completely hands free operation......connect to pump, enter amount required and push delivery button.
pump turns off when amount reached or container is full.
am i wrong ? (probably:Blush:)
lebesset
760
nope , just like other normal fuel pumps , no preset
wouldn't use one if there was .....if I made an error I might overfill , better to watch the gauge and stop at the required amount
don't forget the gas factories use the weight/volume method because it is the safest method far more precise and much less dangerous than using a device that SHOULD cut off at 80%
when a gas factory fills a bottle it MUST contain the volume stated under the sale of goods act
when a lpg pump delivers at a filling station it MUST deliver the stated volume
as I know from my own experience the 80% cut out devices are only approximate
I prefer the precise and therefore safer method
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
for filling the butane bottles .i use a butane clip on to old threaded type adaptor. i am then left with the continental thread i took a propane bulk head fixing and had a machined brass bit made that can take the correct lefthand thread nut .(taken from an old reg. it also as the rubber seal. )this then takes our uk propane pol fitting .
i also have spanish clip on top left hand butane thread i have also an other one for some italian or an odd english, 20mm and 21mm and i think spanish is 27mm clip on.
i would like to say i can fill every bottle but sure someone comes up with another one.
i do have some spare machined bits if our paths cross and you need one .the bulk head fixings can be giot from BES. on google.i remove their threaded bit and screw in mine.
i have also had a discussion with one of the makers of the adaptors he said he as never been asked for one but could makeone if the demand increased. reimo used to list all the bits in their catalogue.either to fill german bottles outside germany or convert other bottles to suit german regulators.
43,319
49,393
i know you dont hold the filler nozzle, i can imagine it gets a bit chilly, so you must have to keep the 'delivery' button pressed and release when you have what you want.
correct ?
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
correct .just come back from filling 2 x 47 kg bottles .actually we put 80 litre in each. cost 52.9pence a ltr.neighbour trying out a fill up . think its something like 49p when they fill my big tank in garden. ley it nearly run out now .dont want a big bill just before leaving .ha ha.
43,319
49,393
probable price difference will be the vat.....5% on domestic fuel and 15% (for now) on road fuel.
garage forecourt pumps will be road fuel vat regardless of what you say its for.
bit like saying the 5ltrs i just put in the can is for my lawnmower, can i have some vat back.:winky:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi pappa ,how do i get 2 x47kg bottles in the gas locker?
may put one underneath .weld a nut on a side callit the top drillit and make an outlet. easy. couple of bungies to the chassis got me sen a time bomb. ha ha
