- Jul 28, 2010
- 15,475
- 20,756
- Rapido 7090F 3 litre 160
- May 2010
A much better explanation here
Broken Link Removed
Broken Link Removed
I figured that way lets a little bit of air get underneath to cool them and I can still get a thin bladed knife or cheese wire in there if they ever need to come off.
They are not that flexible Brian
I fitted it about 18 months ago and he has just sold his van and it was working perfectly still, so I can assume they are as good as a conventional panel albeit a bit more expensive( about 50% more) but on the plus side they are discreet and east to fit.How long ago Nigel? any feedback?
Good point, although I fitted my own conventional panel with 2" aluminium angle bonded to the roof with PU40 and fixed to the panel using rivnuts so I am still able to remove the panel if I need too for any type of maintenance, hopefully this will never be needed.If you deduct the cost of brackets from the install budget they are possibly no dearer.
A common mistake made by probably 8 out of 10. The red dot denotes the front of the aerial (for the purpose of pointing at a signal) For travelling it should point to the rear.
Extract from status manual
