Reasurance .......
Discussion in 'Motorhome Chat' started by gordoncbrown, Jun 26, 2012.
  1. gordoncbrown
    gordoncbrown Funster
    Oct 2, 2011
    837
    568
    Scotland
    Just finishing sorting things out for heading odd today. We had not used the fridge on gas since it had been checked at the habitation check so I decided to check all the appliances as we will be wildcamping some of the time we are away. Everything else worked except I couldn't get the fridge to light. Probably not waiting long enough for the gas to get through. I's working fine on 240 and 12v. Didn't have too much time to mess about as I had to head to work. Is impatience the most likely cause?
    Hope to see some other Funsters on our way to Poitiers
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    Probably is impatience. We used to have a similar problem sometimes with our Autoquest 100 from same group.
  3. normanandsue
    normanandsue Funster
    Dec 31, 2010
    1,365
    5,269
    Dunfermline - Scotland
    Gordon,
    Perhaps if the fridge has not been used for gas for some time it may take a little longer for the gas to reach the burner, also check the internal stop valve usually situated somewhere in the kitchen area. It may be when the habitation was done the stop valve was turned off and needs to be turned on again.
    Finally your observation may be right it does take a while for the gas to ignite but keep finger on ignition button on fridge until the ignition light goes out.
    Have a good trip.
    Norman
  4. buttons
    buttons Funster
    Aug 27, 2009
    14,301
    11,595
    Hertfordshire
    Could be as simple as a spider or even a mouse nesting in your igniter or chewed through the power cable. Both very unlikely of course but you wouldn't be the first.:Sad:
  5. gordoncbrown
    Oct 2, 2011
    837
    568
    Scotland
    Not as unlikely as you might think. We had to get the heater repaired earlier in the year. It was a wasp that was in the combustion area that was preventing ignition. That was a first for us..:Smile:
    • Like it Like it x 1
  6. Touchwood
    Touchwood Funster
    Aug 23, 2011
    770
    733
    NE England
    Quite a coincidence Gordon - decided to do the same thing on my Compass last week before heading off to Northumberland - and took me ages to get it lit. Eventually resorted to looking at instructions (!) You need to turn the gas control knob to full on, then hold in, and just keep clicking the igniter until it eventually catches. I have found with such devices in the past that it actually has lit, but wasn't viewing the flame through the little viewing port exactly right - in the case of mine though it was very clearly visible when it did eventually light.
    Hope you get it sorted.
    Mike
  7. gordoncbrown
    Oct 2, 2011
    837
    568
    Scotland
    Yip. Impatience it was. Got it lit at lunchtime there. Almost need to have my head inside the fridge to see the flame. I'll not do that with the oven.:Rofl1::Smile::Rofl1:
  8. Lindylooj
    Lindylooj Read Only Funster
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    Ok its me being ignorant but I thought that if you had your gas turned on and turned the fridge to gas that was all you had to do? Where do you find a flame? Durrrrrh enlighten please - by gas if you want! :BigGrin:
  9. gordoncbrown
    Oct 2, 2011
    837
    568
    Scotland
    Inside the fridge at the back lower left side, on the model of fridge I have, there is a small round "window". Once the fridge is lit it has a blue flame in it and is working. Hope this helps
  10. Lindylooj
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    Thanks for that, will have to look next time I go out to the van. :Smile:
  11. normanandsue
    Dec 31, 2010
    1,365
    5,269
    Must have a look I thought once the igniter stopped clicking fridge was working, it always has up to now. Never knew you could see a little gas flame, must remember to look when I am next in "The Beast"
    Norman
  12. GJH
    Aug 20, 2007
    27,349
    34,950
    It all depends on the fridge model. Our Elddis had one like Gordon's but the Burstner has no little window - you know it's lit if the light by the control is not flashing/clicking.
