Rear wheel hub/drum/bearings (1 Viewer)
anjer
9
1995 Fiat Ducato based Hymer: I had a new rear hub/brake drum and bearings fitted at 70000 kms(44000 miles) because the outer track of the inboard bearing was loose and rotated in the hub and wore away the interference fit. My service man tells me that he suspects the other side is now doing the same thing at 101 00 kms (63 000 miles). Anyone had similar issues with rear bearing or have I just got a bad batch of machined hubs from vehicle manufacture
Thank you
Anthony
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Thank you
Anthony
He could remove race and re fit with a chemical bearing lock(locktite for example) now and save the hub before its to late
Mike0648
3
North Devon
coachbuilt
on and off for 20 years in UK
Loose rear outer bearing fit!!
If your 'technician' was to clean a new bearing outer with loctite degreaser and then use Loctite 640 sparingly on both the hub and the bearing outer, bring together and leave for 24hrs the loctite will have cured and the problem should be solved!::bigsmile:
