Rear View Camera
Discussion in 'Tech/Mech General' started by electrajohnt, Apr 23, 2014.
  1. electrajohnt
    electrajohnt Read Only Funster
    Oct 27, 2013
    79
    39
    Stoke on Trent
    Somewhere on this listing is hopefully a photograph of a rear view camera that is fitted to our Camper. We have just used the Camper for he first time and could not get the camera to work. I have no literature for it, it does not have a makers name on it.
    Does anyone know how it works or even how to switch it on. I tried the on button but nothing happened.
    I have two more images I could post if required.
    Thanks JohnT
  2. MikeD
    MikeD Funster
    Dec 21, 2011
    2,051
    1,827
    London
    Usually it would only be a rear view camera when the motorhome is in reverse. Sometimes it may take a few seconds to automatically power up and provide a signal.
  3. electrajohnt
    Oct 27, 2013
    79
    39
    Stoke on Trent
    No info
    There should be a couple more images here now. Only writing is as shown on the back of it.
    It is connected to a wire that vanishes into the lining of the roof, I assume it emerges at the camera on the back of the van.
    The one thing I have not tried is to sit with the van in reverse and then try to switch the viewer on.
    I have tried to switch the viewer on with or without the ignition on without success.
    Is there a way of testing the device is live or getting a signal.
  4. taffybloke
    taffybloke Funster
    Dec 6, 2011
    324
    216
    West Wales
    If that cable is going to the rear camera where is the cable to the power socket. Where is it getting its power from?
    Mike
  5. electrajohnt
    Oct 27, 2013
    79
    39
    Stoke on Trent
    Big Job!
    Hello Mike.
    I don't know. I am not sure what I should be looking for. The wire you see goes into the cab roof lining. At the back of the van another wire (I assume it is the same one) emerges from the van body and is connected to the camera.
    Having just been looking at a link to ines for sale on ebay the wireless ones seem cheap enough, probably better if I fit one of them and forget this set up if it's going to be a big job to figure it out.
  6. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,748
    3,252
    Eastbourne East Sussex
    The wireless ones are not free of problems. I had one on a previous MH and it suffered from some interference. Once in France in a town the rear view disappeared to be replaced with a TV picture. Probably from one of those wireless DVD repeaters, they all work on similar frquencies.
  7. daisy mae
    daisy mae Read Only Funster
    Mar 12, 2013
    676
    596
    Leicestershire
    I have a twin rear view camera and a 7" rear view mirror monitor, at the right hand side on the monitor there are touch buttons, and I can flick between the cameras which ever one I want on, I can see on your monitor the buttons are at the bottom, when you switch your ignition on? after a couple of seconds the monitor should come on if not wired to work in reverse only , try reverse and see if it comes on then, if not try to see what the buttons are for, there must be an on/off button I would have thought, some one more knowledgeable will be along shortly and hopefully you can get it working, I wouldn`t like to be without mine.
    Can you see a name on the monitor, ? or Google rear view cameras and see if you can find one like yours with some names, and there is lots of information how they work etc, on the web.
    Sorry I cannot help.
    Good luck,
    Margaret
    PS My power comes from the 12volt under the dash, I believe, sometimes power is taken from the reversing light, if it is connected to come on when reverse gear is activated.
  8. mapa
    mapa Read Only Funster
    Sep 16, 2013
    29
    42
    Colchester
    I had a similar camera on my van it was made by a company called " vision" the camera itself has a habit of failing so that could be Your problem. I took out the camera part and sent it back to the company who tested It and then sent me a replacement. Cost about £100. Also on my van the rear view mirror part will only respond if I use the remote control that comes with it.
  9. RS_rob
    RS_rob Funster
    Dec 14, 2013
    885
    605
    Turnford
    that looks like the same model I have
    mine only works when reverse is engadged & it takes a few seconds to power up.
    I do know the cable from the screen runs to a box behind the dash & all the wiring is plug n play & black apart from a pink cable switching i prsume & live & earth. this is then connected to the camera.
    mine is all behind the dash on the drivers side & once found it cant be missed :Smile:
