Rear view Camera power (1 Viewer)
Geoffers
506
215
Groby Leicester
For some time I have had the rear camera plugged into a lighter socket on my 2009 X250. So thought about time I plumbed it in properly . Couple of questions before I rip the dashboard apart.
I understand the best live is from the ignition (camera on all the time)is there a spare connection there or do I double up with another? Where's the best place link the neutral ? :helpsos:
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
do you have a 12v power plug in the dash?
I have a cigarette plug and also a 12v plug in my dash.. certainly the 12v plug is live all the time and I can get to it and attack the power and earth there.. or even to the main fuse board for the RV.. but it is an RV rather than a european motor home.... but the principle is the same.. a good meter will allow you to probe the power and earth.. just add an inline fuse.
Bob
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
I fitted one myself last year , I mounted the screen on the obsolete rear view mirror ,ie no rear window, ran the cable through the top lockers, fed a feed using clips from the cab lights, also a feed from there to a toggle switch otherwise it's powered up all the time , the lights are activated by ignition and the doors, so the toggle cuts the power to the screen and camera when not in use. Peter :thumb:
s7ev0
May 31, 2010
462
809
Globecar Summit
Since 2009
Just done mine, and was very pleased to find that the CD/radio had a spare connector for an ignition live lead. Might be worth a look.
I simply plugged into that and hey presto - ignition on = camera on! Didn't bother with reverse wiring for the second camera, just tap the V2 button on the screen and Bob's your uncle.
Steve:Smile:
43,295
49,270
if you can use a multimeter then check the cab fuse box for ign switched circuits...there will be one, just a matter of finding it.
put the meter on a 'dead' fuse (ign off) and check it is ign switched by turning ign on and off with the meter connected.
there may even be a spare 10a fuse in the box....or whatever fuse rating the monitor requires.
a spare 20a fuse could be reduced to whatever amps the monitor is rated at.....providing it has nothing else connected to it.
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Fiat X250?
No need for a reverse camera!
You don't want to be reversing one of them!:winky:
Sorry, as a Tranny owner, I couldn't resist!:Blush:
Geoffers
Geoffers
506
215
Groby Leicester
Fiat X250?
Camera used to check the toad is still there on the A Frame so can't reverse with that on if I tried:thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
In that case save yer dosh, the car behind the toad will let you know if it comes off
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i just tagged mine on the back of the accessory socket on the dash as its easy to get at and ignition switched.
there is a torx head screw under the rubber mat in the cup holder and i think thats all that holds that part of the dash in apart from a few clips.
