Rear skirt/mudflap (1 Viewer)
C&G
5
3
Norwich
Looking to fit a full width spray skirt to the rear of the MH, I've acquired 9ft of cord reinforced conveyor belt that's about 1/4" thick, so it should pop rivet/washer ok. Wondering whether to mount it so it pivots/swings or fixed. Any advice on mounting it would be appreciated i.e. brackets. Was thinking alloy 'U' channel across the top. If anyone's got any images of theirs please?
Thanks in advance Clive.
Aug 7, 2007
669
608
Dundee
Elddis Autoquest 195
since 1975
Get a length of 40mm right angle aluminium , pop rivet to van and then pop rivet the belt to that, like you say, using 20/25mm rivets to ensure that it will pull tight on both sides of rivet's on the washers to ensure a tight fit.
BTW use aluminium rivet as the will tighten easier that stain less steel and a cheaper too
Sep 16, 2010
2,994
2,848
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Put a couple of "stays" on it so that when you reverse, it doesn't get in a mess !!
rolandrat
436
258
Lancashire
Hi Top
A length of rubber that thick to be suspended across the rear of the motorhome would need some substantial angle brackets to hold it in place then there's the extra weight to take in consideration. Wouldn't the lightweight brush type be a better option?
denisejoe
5,564
11,632
Warden isle of sheppy
Since 2004
I've put similar on my van but have just made mudflaps with the belting. A piece going right across would be a substantial weight. Make sure what you fix it to is solid.
Joe
old-mo
Extra Special
16,341
93,473
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Bought mine from here = Broken Link Removed
Just cut to the required width,,,, lightweight, strong and comes with the aluminium channel, which is easy to fit and light..:xThumb:
Jaws
23,821
71,964
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
PLEASE ! Make sure it is a good few inches off the ground :xThumb:
There is absolutely nothing worse than following a van that has them more or less dragging on the ground
They flick up all sorts of crap and cover the following vehicle in dust if on a loose surfaced road
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Make sure there fixed correctly, might not be that easy, because if there not and do come off there's a good chance they will cause damage
Would your insurance be valid
Aug 6, 2013
11,941
16,527
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Aluminium rivets will corrode very quickly. Use stainless screws & nuts. Anyone noticed, or considered, aerodynamic drag caused by a full width spray guard? I'd assume it must be substantial given the gap under the nose of a MH.
