Rear Mounted Bike Racks.
Discussion in 'Motorhome Chat' started by Zajacp, Jun 10, 2015.
  1. Zajacp
    Zajacp Read Only Funster
    Sep 11, 2012
    92
    57
    Cheltenham
    I need to fit a cycle rack to the rear panel of the m/h with the intention of carrying 2 standard bikes . I am a bit concerned about the weight that will be put on the panel with regards to possible movement and water ingress into the sealed joints. I have seen plenty of m/h with racks on and was wondering if
    Any one has any serious issues with them.
  2. CandC
    CandC Funster Life Member
    Jan 22, 2014
    196
    331
    Cornwall
    I haven't got a bike rack yet so can't answer your specific question, but I have been looking at tow-bar mounted racks. That could be an option you could consider if you have a tow-bar :)
    Someone will be along with more info I am sure!
  3. SMB
    SMB Funster
    Apr 26, 2013
    667
    591
    north shields
    I have a 2-bike Fiamma rack mounted on the rear panel of mine and it seems secure enough. However it was already fitted when I bought the van, otherwise I would have got either a towbar-mounted rack or one which winds down as its a bit of a pain to get the steps out every time to take it off/put it on along with the cover. The plus side is it makes it harder to be stolen :)
    • Like Like x 1
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,135
    15,070
    Leeds the one up North
  5. Chris
    Chris Funster Life Member
    May 5, 2010
    16,624
    35,928
    kent
    We had a 4 bike one on our last van.
    The weight was too much for the bracket. The rack started to come away from the van halfway across Spain one year which meant loading the bikes inside the van.
    Same trip the fuel filter broke and diesel was spewing out when we arrived at our Spanish site.
    Eventually got onto our pitch, stinking of diesel then began to unload.
    Two adults, two kids and four bikes.
    Got some funny looks from our neighbours.:LOL:
    I would go for a tow bar one next time if weight allowed it.
    • Like Like x 2
  6. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,510
    9,938
    The biggest issue with wall mounted bike carriers is many people overload them. This does warp the wall and strain the fixing points leading to leaks. have seen many of them over the years and its something I pay particular attention to when buying used vans
    • Like Like x 2
  7. Chris
    May 5, 2010
    16,624
    35,928
    kent
    I don't think we overloaded ours to be honest.
    It was the ramps on the ferry ( in my opinion) that put too much strain on the rack/ brackets
    • Like Like x 1
  8. TheBig1
    Nov 27, 2011
    7,510
    9,938
    put 40kg plus of bikes on a rack bolted through the wall in 4 points and every time you go over a bump, the bouncing of the bikes and rack will overload it. max weight on a fiamma rack is 45kg from memory. 2 adult bikes and 2 kids bikes has got to be more than that, unless they are ultralightweight racing bikes. put my son-in-laws bike in the back of my 4x4 the other week and it must of been near 2okg to lift and is a normal mountain type bike
    • Like Like x 2
  9. Chris
    May 5, 2010
    16,624
    35,928
    kent
    I think our rack limit was 60 kg , but either way I agree that bumps and ramps possibly double the strain.
    Not tempted to get another bracket mounted one.
    • Like Like x 1
  10. weekenders
    weekenders Funster Life Member
    Apr 30, 2008
    2,186
    1,240
    Leicestershire
    We have fitted a Thule 2 bike rack, it fits on the tow ball and is very sturdy
    • Like Like x 1
  11. Zajacp
    Sep 11, 2012
    92
    57
    Cheltenham
    Thank for all your recent replies, my concerns have been answered .i think I'll go for a tow ball set up and leave the structure of the van alone.
    • Like Like x 1
  12. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,328
    5,331
    East Sussex 01-580-881288
    Properly mounted with the correct rack and professionaly fitted, mounted bike racks should not be a problem, max load on a Fiamma is normally 60Kg
    We have fitted many without problems
    Peter
  13. Jeannette van den Oever
    Jeannette van den Oever Read Only Funster
    Oct 25, 2014
    160
    193
    Cambridge
    Doesn't towing further limit your speed (says the M5 driver ;))?
    We are a family of 6, with a factory fitted fiamma 4-bike rack. It's rated for 60kg but as most folks have pointed out, less expensive steel mountain bikes will come in at around 16-20kg.
    We have the lightest 3 on the back, smallest one with all the other paraphernalia in the garage and the other 2 secured inside the van with an impressive feat of bubble wrap/bungee engineering.
    You should be fine with just 2 on the back wall, surely?
    • Like Like x 1
  14. Techno
    Jul 28, 2010
    14,135
    15,070
    Yes I carry an electric bike & a lightweight mountain bike
  15. Chris
    May 5, 2010
    16,624
    35,928
    kent
    I am sure it's fine.
    Just keep an eye on it though just in case.
  16. The Old Man
    The Old Man Funster
    Jan 23, 2016
    455
    3,465
    Wales
    I've never really liked rear mounted bike racks. Give the aerodynamics of most vehicles you end up giving your bikes a 1000 mile sandblasting that penetrative the best bike covers! With my bikes worth nearly £3000, not something I want to inflict on them. Also IMO most Motorhome rear mounted racks look very easy to remove with a couple of strong bodies to support it, while another cuts Rack complete with bikes off. So make sure strong chain secures everything to the chassis.
    I've had a tow ball rack, that worked well, except for the dirt issue and again security. You also lose the use of your tow ball.
    When I had a Land Rover and Caravan rig, I purchased from Land Rover a bracket that fitted between the car and tow ball, then a separate bike Rack dropped dropped into the bracket, so I could tow the caravan and carry my bikes.
    I admit that my bikes influenced my Motorhome choice, a garage big enough for my bikes was high on my list of requirements.
  17. The Old Man
    The Old Man Funster
    Jan 23, 2016
    455
    3,465
    Wales
    [​IMG]
    [​IMG]
    Towing and bike rack.
    Don't forget you will need a number plate and lights bar to stay legal.
  18. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    1,952
    1,697
    Bungay Suffolk
    Had 3 vans ALL with rear fitted Fiamma 2 bike rack and no problems at all.
    Good luck.
    Mitch.
