Rear Lights
Discussion in 'Auto-Trail' started by kensteve, Mar 21, 2012.
  1. kensteve
    kensteve
    Jun 24, 2011
    22
    9
    Chalford Hill, Stroud, Glos
    Please can anyone tell me how to change a stop/tail lamp on 2010 Autotrail Scout. Cannot see how to remove the lens to get at the lamp without forcing it.
  2. spannermanwigan
    spannermanwigan Read Only Funster
    May 22, 2008
    394
    207
    wigan, lancs
    Probably need to remove complete lamp, then access bulbs from behind.
    check behind lamp for mounting screws etc, don,t force lens will be a very
    expensive mistake if you do.
    photo of your rear lamp may help.
    regards
    Steve
  3. JayDee
    JayDee Funster
    Oct 7, 2007
    1,312
    166
    N. Devon
    If yours is anything like ours:-
    Remove taillight assembly (4 screws two at top, two at bottom)
    Unscrew metal clamp/holder piece on the back of the assembly (two screws) which will enable you to change the lamp(s).
    Reassemble in reverse order. :thumb::BigGrin:
    But, yes, a photo would help.
    John
  4. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,880
    Full timing in the van
    Take old bulb out then put new one in:Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1::Rofl1:
  5. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Post a photo. On my mh the lamp cover is held in place with a hard rubber seal. Pull the rubber seal away and the lamp cover just lifts off.
    Jim
    :Smile:
