Rear Leaf Suspension replacement - flat springs
Discussion in 'Tech/Mech General' started by N&K, Aug 18, 2009.
  1. N&K
    N&K
    May 26, 2008
    220
    42
    Berkshire
    I would like to replace our MH rear leaf suspension as the current springs are flat or even slightly inverted and resting on the stoppers on both sides, it was like this when i bought it but didnt spot it due to inexperience. Has anyone done this before or got any good supplier/fitter suggestions? (no air suspension thanks)
    I have a few quotes, one for heavy duty 3 leaf springs and one for 2 leaf + Aux Leaf (what ever that is?)
    Thanks in advance
    N&K
  2. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    My next door neighbour is having his old Talbot springs re-worked next month. A local firm is sending them to Sheffield for heat treatment. He's away now so can't ask the price.
  3. johng
    johng Read Only Funster
    Aug 15, 2007
    588
    Kent/Sussex UK
    I have a feeling reworking them could be 2-300 :( ...
  4. N&K
    N&K
    May 26, 2008
    220
    42
    Berkshire
    Up to now, the cheapest is £420 for a new set with extra leaf.
    N&K
  5. johng
    Aug 15, 2007
    588
    Kent/Sussex UK
    I dont know how old your van is N&K but maybe you could get some similar springs off a commercial vehicle, used and from a slightly heavier chassis ?
    as long as you know the spring length and other dimensions, and the back axle weight, you could be halfway there?
    leafspring suspenion is pretty agricultural, and rear exle comfort / or chassis handling, can't be a high priority really ?
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    what you need it 1) check your load weights at a public weighbridge sounds like you are over weight and 2) spring assistors, just bolt onto existing springs. A firm in Portsmouth usesd to make and market them. "McKinalley's" I think; they also repair and make new springs. Looks like they changed their name to
    Leaf Spring Manufacture & Repair Services | Hampshire, ML (UK)
    give them a ring and enquire about rebuild and/or spring assistors:thumb::thumb:
  7. N&K
    N&K
    May 26, 2008
    220
    42
    Berkshire
    Thanks for the replies, heres some pictures of my "suspension" if you can call it that still :Eek!: not sure the next MOT will be a breeze.
    Empty Motorhome and flat Springs:
    [​IMG]
    [​IMG]
    [​IMG]
    I'll call the Spring Assist place, thanks.
  8. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    don't look like they have seen grease in a while, spring assisters will sort that out.
  9. andyman
    andyman Funster
    Sep 23, 2007
    1,154
    509
    Leicestershire
    Got to ask why not air suspension. I had the same problem on my Autotrail and fitted air bags, problem sorted plus you can adjust the presure to suit the load. I opted for the simple set up of no on board compressor. Cost is around £330.
    Andy
  10. N&K
    N&K
    May 26, 2008
    220
    42
    Berkshire
    Hi Andyman
    no problem......I read a few bad reports on the airbags, as the springs are dead, adding an airbag will make all the MH weight concentrated on one single point in the chassis (where the air bag is) instead of being spread across two points (either end of the leaf spring, a metre or more apart).
    With all the weight concentrated on one single point the chassis can (very worst case scenario) bend or buckle which could damage the MH, i.e. panel buckle. The price difference between replacing the springs or getting air isn’t massive so decided on springs.
    I'm sure this response might ignite an opinion divide but I have decided to replace what is broken instead of putting a plaster on it.
    N&K
  11. Andy 01424
    Andy 01424 Read Only Funster
    Aug 10, 2009
    154
    Hastings East Sussex
  12. walburga
    walburga Funster
    Aug 20, 2007
    300
    99
    Leyland
    I had the same pproblem, 'inverted springs' on my old Elddis 320. I fitted a set (2 each side) of helical springs from Grayston Engineering (Ithink that's where they were from, it was 5 years ago !).
    That saw the rear of the van rise by about 1 1/2 inches, the springs weren't inverted anymore, and no more swaying round corners. Wish my merc was as stable round bends !
    The job took me a couple of hours. No drilling involved, just a bit of brute force especially when fitting the springs. Definetly needed spring compressors to make job easy.
    regards
    Allen
  13. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,924
    roche cornwall
    hi, i would change your springs .there is a place in nottingham makes new ones. i just changed mine on my trailer got them from peak trailers near alcester. having worked on trucks n travelled alot fit new springs they can be bodge repaired any where even if only to keep the wheels turning .air can be expensive. by the look of photos your are past their sell by date. google leaf springs i, sure you will find something. .cheers alan.
  14. N&K
    N&K
    May 26, 2008
    220
    42
    Berkshire
  15. Uncle-Steve
    Uncle-Steve Read Only Funster
    Jan 24, 2008
    20
    One of the posts above mentioned the loading on the chassis. Most air assist kits pay little attention to the extra strain on the chassis, however the Dunlop kits do have different brackets, as theirs are designed to fit over and along the chassis to spread the load. With regards to the Ducato/Boxer vehicles, most, well all the ones I saw at the NEC were already resting on the bump stops, so no real room for the leaf springs to work. Unfortunately this quite often results in the bump stop literally falling apart!
    Looking at the cost of replacement or reworked springs, it is cheaper to fit an air assist kit and then enjoy a softer more comfortable ride with better stability. Obviously its no good fitting any sort of spring assistance if the bushes in your existing set-up is past its sell by date.
    Any respectable retailer will sell you a spring assistance kit (air or steel) and offer to give you a FULL refund if your not satisfied with the result, so do ask when your purchasing your spring assistance kit.
    Both steel spring assister's and air assistance will restore the ride height of your vehicle and give it a firmer ride, but when air assistance is used, you do also gain a better ride comfort and also make the van quieter.
  16. MAUBRI
    MAUBRI Funster
    Aug 9, 2008
    196
    4
    Lanner - Cornwall
    Hi There,
    Just to add my two penny worth, When I had my 1996 Hymer with garage I to noticed the sag to the rear leaf spring. It was Fiat based so I removed both sides and took them to a firm in an industrial Site off the Ringwood road in Upper Parkstone,Poole, Dorset and had two extra leaves put in( I could drive there, but I am afraid I cant remember the name). This did make the ride firmer but increased the stability and it LOOKED RIGHT which helps if you err on the wrong side of the loading. This was back in 2006 and it cost me £200 in total.
    All the best in making your decission
    Brian
