Rear drag link?
Discussion in 'American RV's' started by WinnietheBrave, Jul 24, 2012.
  1. WinnietheBrave
    WinnietheBrave Read Only Funster
    Jun 28, 2010
    187
    17
    S. Wales
    I had an advisory on my MoT, the guy showed me that when the steering went from side to side, that one of the drag link ends was showing to much movement, (up an down)
    Now I'm no fitter, but a mate who is, reckons they are spring loaded and are designed to move like this.
    Anyone have any knowledge in this area?
  2. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Grease it up and see what happens next year. Yank drag links do tend to have play normally:thumb:
  3. WinnietheBrave
    Jun 28, 2010
    187
    17
    S. Wales
    Hi Si, he did grease it at the Mot station, still reckoned it should'nt move though.
    Good thing was though, it was the local counsil. They have a yard to do their own fleet. I never knew they did private Mot's. Anyway I'll be there every year from now on :thumb:
    Maybe worth a try for others looking for RV MoT's Who knows how many counsils have this facility?
    • Like it Like it x 1
  4. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,789
    6,053
    Mansfield,Notts
    99% Of them:thumb:
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,096
    17,764
    YO11 2BD
    Scarborough must be the other 1% then :cry: they use the local VOSA site
    got mine booked in at Beverley council depot on friday.
    and this year they AINT using the rolling road to test the parking brake :Cool:
    last year was on the rollers and lifted out eventually but scared the bejazus out of me and just about tore me leg muscles pushing the pedal :Eeek: (the tester was newly qualified)
    Geo, do you know the procedure for the dynomometer (is that the correct term ?) test at this size ?
    speed etc....and who drives ?
  6. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,284
    7,981
    West Norfolk
    Larger ball joints, like the one on your RV draglink, have a big conical coils spring inside them to take up the play.
    With enough of a heave on a crowbar, even a new one will show some lift.
    I remember in my Army days, we repaired Bedford ball joints with a kit which consisted of the said spring, a pair of cones and a new ball.
    A grease up might sort it!:thumb:
  7. WinnietheBrave
    Jun 28, 2010
    187
    17
    S. Wales
    The lad at work (MoD fitter) said exactly that. Hope I can convince the MoT guy next year.
  8. lou020
    lou020 Funster
    Oct 5, 2010
    414
    257
    huddersfield
    There's no up and down movement in any of our volvo truck drag links.
    vosa would definitley have failed this on mot at our local test station. I would get it changed.
    No doubt someone on here will disagree, but there you go.
  9. maxsdad
    maxsdad Funster
    Oct 5, 2009
    299
    235
    anglesey
    If there is no movement in the front drag link end then it sounds as if you will have to replace the rear one.
    Check if it is left or right hand thread if the drag link is a straight bar it is possible someone may have refitted it the wrong way round no determent really but if the spares cat says l/h thread it will be r/h.
    dave e
  10. WinnietheBrave
    Jun 28, 2010
    187
    17
    S. Wales
    Here is a picture of the drag link? the arrow shows direction of movement. the o/s shows about 1-2mm of play but the n/s is about 4-5mm
  11. olley
    olley Funster
    Jul 29, 2007
    3,827
    2,381
    Ipswich
    I would have called that an idler arm not a drag link, and my opinion for what its worth is no it shouldn't have any play when you wind the wheel from full lock to full lock.
    Ian
  12. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    The bit marked with the red (faint) arrow is a ball joint pure and simple, on the drag link, so needs replacing. We all assumed you meant the drag link bearing which is a totally different beastie, basically what the arm pivots on/center 'bolt' on that arm.
    Ivan at West Midlands American vehicles would be my first port of call, http://www.american-vehicles.com/ mind you may need to be sitting down as I'm sure I've seen these on flea bay and they ain't cheep:Sad:
  13. BernieNUFC
    BernieNUFC Read Only Funster
    Jul 26, 2012
    Northumberland
    The testers manual states as below: its been a long time since i worked on them but if it is easy enough to see without excessive force then better to be safe than sorry,
    Relative movement due to excessive wear MUST
    be distinguished from relative movement due to
    built-in clearance or spring loading of a joint.
