Rear camera dilemna.....maybe (1 Viewer)
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Just bought a twin rear view camera setup, and have realised there may be a problem.
The ideal area above the rear doors (Transit) is a sealed body section, i.e., the roof at that point is double skinned, so no access to route cables or bolt the unit down.
So I reckon the only place I can logically mount the cameras is on the door(s) themselves.
My question is - will the constant shutting of the doors harm the cameras in any way? And if they are mounted on some sort of shock absorbing material, will this affect the rear vision with wobble?
Thanks in advance
Apr 27, 2008
11,842
14,066
Eastbourne East Sussex
Hymer low profile
Since 1972
You could thread the necessary wires through a hole drilled through both skins, you only need access from one side to fit a grommet. The camera could be fitted with self tappers or if that's not strong enough, expanding bolts as used in stud walling.
Aug 5, 2012
125
99
Southampton
van conversion
since 1981 on and off
Have one on the rear door of our Transit, over a year now no problems so far
