really stupid question, sorry..... (1 Viewer)
calion
406
527
C class
since 2008
The water/coolant level looks like it needs topping up a bit in my new to me van. Its a vw T4 and the plastic header tank thing is globular with a black cap or bung. I cant shift this cap either by twisting or pulling upwards. Is it supposed to be topped up from somewhere else? Is the cap meant to come off, can't see any other way to top up. Sorry, said it was a stupid question, but any tips greatly appreciated!
43,329
49,441
Dont know your van but if its like in the pic it does turn.
roughty toughty mechanic has probably overtighteed it.
scotjimland
2,324
10,038
A Woosh bang
The header tank may be low when cold.. check again when the engine is at full working temperature..
if still low , when systems cold again top up with coolant, then keep an eye on it over a few days..
.. it shouldn't lose water unless there is a hose leak or head gasket gone
calion
calion
406
527
C class
since 2008
Thank you both. Yes the cap does look like that one Papajohn, but won't budge grrr. The level appears to be below minimum, so I think it needs a little. Will note what you say about shouldn't lose water and will monitor after top up IF I can ever remove cap!!
grumps147
1,840
2,448
St.Helens
Between
MH 12 yrs -Tent/Caravan 49 years
We have a vW estate, not van, and our header tank is round with markings about half way up at its widest point, so it may not need topping up right to the top. You will find when you do remove the cap that pressure release will affect the level. Due to arthritis I now find myself using devices to help loosen things, sometimes something as simple as a cloth gives me a better grip, others it has to be a tool like those slackening off oil filters use where you tie a band on a handle around the lid and use the handle as extra leverage. It will be a twist fasten.
Cal54
3,806
62,013
Southport, UK
Leisuredrive Renoir
Since 1996
Have had problems with similar cap in the past. I used a rubber mallet to help it on its way - but do it gently!!!!
43,329
49,441
I think the problem with the cap is its plastic.
it will contract and expand with the heat and will self tighten.
my plastic oil filter housing cap was the same...i had to buy the proper removal tool or risk destroying the cap and possibly the housing.
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Since 2012
How about a hair drier just on the cap itself? May expand it a 'nats'? Enough to make it budge when you give it a few extra 'Isaccs' with some tool or clothed grip.
thehutchies
1,527
1,776
The Wheelèd Shed
Our T4 is just the same.
I put the cap on just finger tight and the next time I need to remove it, it takes a hammer and chisel.
Don't be gentle with it!
cruiser
4,219
4,951
northampton
coach built elddis 400
since 1978
some one beat me to it a hairdryer.
43,329
49,441
Heating the cap will expand it even further and make it tighter.
the cap needs cooling to contract it....but it still wont contract enough, it needs brute force.
scotjimland
2,324
10,038
A Woosh bang
Maybe a drop of Vaseline or Silicone grease on the male thread before replacing ?
good idea - bad ?
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
I agree with pappajohn regarding heating the cap. It is an internal thread and will expand.
What ever you do --- Do NOT try to remove it when hot. The pressure release may allow the coolant to boil and spray you.
Puddleduck
12,385
43,990
Scottish Borders
Without at present
On and off for many years.
I'm trying to work out why this was a stupid question.
We've all had things that we think should come off but don't, well at least not easily, and been frightened of breaking something.
I thought it a great question:)
MJG1959
136
124
Cleveland UK
It's a question of leverage I would of thought.
Can you get some mole grips on it? To exert some?
Puddleduck
12,385
43,990
Scottish Borders
Without at present
Sounds daft but sometimes if you turn the wrong way just a smidge you can then turn the correct way. I've been known to use two hands on jammed caps, and also a percussion adjustment device in extreme circumstances.
calion
calion
406
527
C class
since 2008
Thanks everybody, no luck with it this afternoon, will try again tomorrow. Might have to resort to brute force in the end.
Puddleduck
12,385
43,990
Scottish Borders
Without at present
Perhaps a little heat would be worth a try - I know it is an internal thread and will expand etc etc BUT a bit of heat might just budge something that was sticking. Either heat or a bag of frozen peas over it :)
43,329
49,441
As a last resort this MAY help if you can use a saw and there is access around the cap.
Take a short (1ft) length of 2 x 2 timber.
cut a half inch slot ACROSS one face (2 cuts and chisel out between) a couple of inches from the end and deep enough to fit over the handle of the cap...maybe half an inch deep.
That should give you the extra leverage needed.
if that breaks you're going to need pipe pliers or similar.
calion
calion
406
527
C class
since 2008
I see where you're coming from but don't know if I would trust myself with a saw!!!!
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
I've used this method on metal caps in the past.. beware I nearly always burn myself..
If you run the engine up to temperature you can't open the cap but you can usually losen it very carefully being sure only to move it far enough to ensure it moves on the thread. When you let the engine cool it may well then just come straight off.
Repeat. I've only tried this on metal caps and I have burnt myself.
calion
calion
406
527
C class
since 2008
I just cant believe its on so bloomin' tight!
TheBig1
17,630
43,272
simples.....get a man that can to do it for you
if youre in the AA or RAC phone them and one of their mechanics will drop by and help you. they are not just there for flat batteries and punctures etc
if not pop into an accessory shop like halfords and buy a strap wrench. or look in the kitchen drawer for a lightweight version sold for jars. be prepared to give it some force if need be
the idea of a hairdryer may help if you could only heat then cool the cap and not the bottle. however its unlikely to work
Apr 13, 2012
5,543
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Go for it......if you break anything................
Broken Link Removed
(y)(y)(y)
MJG1959
136
124
Cleveland UK
I don't believe they will if the vehicle isn't actually broken down. My wife once rang the AA asking for help when our car number plates were stolen and they refused to help on the basis that the care was still movable and working fully, even though of course it was illegal for her to drive without any plates on the car.
