Really flexible silicone ? (2 Viewers)
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
Odd question here..
I need some really really flexible white silicone. In short it to fill a gap between a UPVC trim and a ceiling that is on a large conservatory roof . The roof is extensively lined and extremely well insulated so wht happens is the structure expands far quicker than the main building so the gap opens up.
I have fitted UPVC trims down the sloping joints and now need to tidy up the very tight gap with white silicone. But it needs to be ultra flexible and it needs to remain flexible or it will not only look rubbish but could pull the plaster on the ceiling as well giving me much work.
The UPVC trim is fixed to the wall not the ceiling so when the roof expands the ceiling moves and the trim on the wall stays fixed.
I have asked mates in the trade but looking for opinions before deciding which brand or type to go with.
Cheers !
Jul 29, 2013
9,071
18,519
Salisbury
Hymer B678DL A class
since 2011
Dow Corning was always the best one when I was working in the trade make sure you get one that has mildew protection in it.
The one used for showers and bathrooms.(y)
Charlie
Charlie
3,211
3,639
Im a newbie
Thanks ! Dow Corning was the very name that sprung to mind .. But I know on this forum there is much talk of Sikaflex. I realise there are lots of types for different applications but in this case its a joint that literally opens every time the sun beats down on the roof.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
I cannot help here but would like to expand the question: Would this requirement be for a high or low modulus selant?
Charlie
Charlie
3,211
3,639
Im a newbie
Some advert Steve N Tracy.
Mitch. (y)
It is some advert ! I have looked at reviews of CT1 mostly on Amazon and the main thing with it is it discolours badly.. That and it is extremely hard to work with hence my comment above it being an adhesive rather than a gap filling expandable sealant.
I will look closer though and again my thanks for the link !
Jul 29, 2013
9,071
18,519
Salisbury
since 2011
@Charlie you need low modulus it accommodates more movement.(y)
DBK
18,022
48,094
Plympton, Devon
PVC, Murvi Morocco
You can get so called flexible gap fillers but they are mostly for filling gaps such as between a skirting board and a wall and I doubt these can cope for the movement required.
Does the gap need to be actually watertight? If not it might be possible to create a sort of sliding joint with uPVC. With a right angled section against the wall and a flat section stuck to the sealing.
Alternatively, a foam draft excluder wedged into the gap, possibly covered with a strip of something, depending on how the conservatory is constructed.
43,329
49,441
But the claim is one product does it all where most makers of these products have several
And that answers the question......an all in one HAS to forfeit some qualities to let others work.
You can't have a product which is very flexible for one job (ie: bath silicon) yet rigid enough for another job.(ie: no nails)
One product for one situation only.....the way to go..
MattR
4,104
38,857
Beds
Panel van
Years
I read it that the Op has a sliding joint system with uPVC strips but wants to fill the very small gap between this uPVC (on the wall) and the conservatory.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Wow that's some MH if it's got a conservatory.
No, its for a Swift hence the need for underwater setting
The above is for the amusement of those who have never owned a swift
Charlie
Charlie
3,211
3,639
Im a newbie
I did what you suggested.. When I put the strip up I stuck a thin white foam strip along the top edge to fill the gap and thought it would fill it and allow for the expansion and contraction rate differences. It looke absolutely woefull and didn't work anyway so I took it off.
No it's not required to be watertight it's for aesthetics only. Of course it's fair to say am I going to sit looking at it but I am just so fussy I can't live with it as it is .. It's better than the awful jagged crack that was there before but not perfect.
Decorators caulking would not last at all . They claim flexibility but there is almost none even with the super expensive brands.
Charlie
Charlie
3,211
3,639
Im a newbie
My thoughts exactly which is why I don't think it's quite the right one. I need a flexible gap filler not an adhesive. I think an adhesive could create a problem as it would join the two elements which are now not tied to each other .
Jul 29, 2013
9,071
18,519
Salisbury
since 2011
@Charlie the other option is to glue the strip to the ceiling but not to the walls thus when expansion occurs it stays with ceiling still covering the gap,
Charlie
Charlie
3,211
3,639
Im a newbie
What I have used is 40mm UPVC architrave which actually looks fine. It blends in with the ceiling a treat but its only 6mm thick so fixing it to the top edge would not be possible. It is fixed to the wall with 1mm thick white double sided tape which I applied neatly so it runs along the bottom edge. Those that have seen it say it looks bob on except the tiny gap along the top where it meets the ceiling..
I have spoken today to a fellow builder in a more specialised area than me who has recommended Sikaflex EBT. So I will get a tube and do a short line and see how it goes.
Cheers mate ! And cheers to those who have advised !
