Re sealing overcab joint
Discussion in 'Tech/Mech General' started by Techno, Mar 7, 2014.
  1. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,139
    15,089
    Leeds the one up North
    This has got to be one of the worst jobs there is :Sad:
    This is how it was a year ago and it only got worse so time to bite the bullet and sort it.
    I kept putting it off because it is so difficult to access and damn awkward
    [​IMG]
    First I cleaned everything with resin polish and pulled out all the loose sealant before cleaning the area to be applied with Sika 205 cleaner Aktivator
    Then I applied a generous bead of Sika 221 and removed the excess with a spare nozzle that I'd cut to a profile with point each side. The points left two grooves in the sealant which would make it easier to remove any sealer outside of the points once set.
    Here cleaning up next day
    [​IMG]
    The existing sealant that was still sound I left in place and just feathered the new stuff into it
    [​IMG]
    [​IMG]
    Overall not perfection but I'm pleased with my efforts
    [​IMG]
    [​IMG]
    [​IMG]
    • Like Like x 3
  2. williamb
    williamb Read Only Funster
    Apr 28, 2008
    42
    14
    Lancashire
    Seal
    Nice neat job. We'll done.:Eeek:
  3. gibbon
    gibbon Read Only Funster
    Feb 25, 2013
    308
    326
    Shatterford
    Very nice job, I'd be really pleased with that if I were you:thumb:
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,757
    6,252
    South yorks
    Nice one :thumb: should have used masking tape :thumb:
    terry
  5. Techno
    Jul 28, 2010
    14,139
    15,089
    I suggest you try that it's not that easy
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,757
    6,252
    South yorks
    got the tee shirt :Wink::BigGrin:
    terry
  7. Techno
    Jul 28, 2010
    14,139
    15,089
    Maybe if I had a tressels and a youngman board and laid on my back perhaps otherwise far too much like hard work in comparisson. Just maintaining the correct distance around two curves is bad enough if you could do it on a bench. I think you're having a Giraffe :Rofl1:
    Got any piccys :BigGrin:
  8. Techno
    Jul 28, 2010
    14,139
    15,089
    Actually Terry now my mind is in gear (champagne night) yes you are correct! I could have used masking tape without bothering too much about the line as it would have taken less time to remove what was outside of my lines (although that only took half an hour including polishing off) :thumb:
    • Like Like x 1
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,757
    6,252
    South yorks
    Don't beat yourself up about it -:BigGrin:-I think you made a very nice job of it -- :thumb::thumb:
    I have had yrs of experience of sealing windows both with masking tape and free hand -if you intend to smooth it off then it;s a lot easier with the tape :Wink: I say again -nice job :thumb::BigGrin:
    terry
    • Like Like x 1
  10. Baycott
    Baycott Funster
    Nov 6, 2013
    6,417
    12,345
    East Sussex
    Nice job!!!!!
    I might even try to do mine now:Eeek:
    John
    • Like Like x 2
  11. Techno
    Jul 28, 2010
    14,139
    15,089
    It came out better than I'd hoped anyway. I've seen many a used van at shows to know what badly fettled up looks like :Eeek: Top tip! don't buy it if it looks sh1t
  12. Terry
    Terry Funster
    Dec 27, 2007
    10,757
    6,252
    South yorks
    Would have taken you five mins to mask up a min to run sealant another to smooth with wet finger and another to pull off both tapes at once :thumb::BigGrin: Same result :thumb: you got there in the end :Wink::thumb:
    terry
  13. Terry
    Terry Funster
    Dec 27, 2007
    10,757
    6,252
    South yorks
    It looks a lot better than some manufactures turn out :thumb::Wink:
    terry
  14. Emmenay
    Emmenay Read Only Funster
    Dec 11, 2011
    364
    274
    Anywhere
    How did you reach the middle? I did mine this morning as well as most of the other joints all over the place, but I could only do as far as I could reach on the overcab bit.:Doh:
  15. Techno
    Jul 28, 2010
    14,139
    15,089
    I stood on this [​IMG]
    Folded mirrors in and grabed the mirror upper arm pivot point to assist mounting the tyre :Laughing:
  16. Daveo2006
    Daveo2006 Read Only Funster
    Jan 25, 2013
    1,168
    987
    kent
    Not sure if you've seen them but i have a sealant kit that has all different silicone profiles which eliminates the surplus that would need to be taken off. A decent gun also helps with a better application.
    I use a power pro gun and have found it the best one I've come across in years
  17. Emmenay
    Dec 11, 2011
    364
    274
    Anywhere
    You must be a flaming gymnast, I try that with general cleaning of the overcab. It leaves me with one hand to work with and usually a few pulled muscles.:Rofl1:
    • Like Like x 1
  18. Techno
    Jul 28, 2010
    14,139
    15,089
  19. Techno
    Jul 28, 2010
    14,139
    15,089
    Yes and try using masking tape too :Rofl1::Rofl1:
    • Like Like x 1
  20. Daveo2006
    Jan 25, 2013
    1,168
    987
    kent
    • Like Like x 1
