Re-charging whilst driving
Discussion in 'Motorhome Chat' started by footballvanbond, Feb 19, 2014.
  1. footballvanbond
    footballvanbond Read Only Funster
    Feb 19, 2014
    INVERKEITHING
    Hi guys , new to the motorhome game but I recently purchased a burstner elegance I821 2008model
    It has the ability to charge whilst driving and also has an inverter, trouble is I am not quite sure how to operate it properly so that its charging and the inverter is heating water at the same time.
    Do i need to operate anything from the control panel to charge and use the inverter ??
  2. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    i think you have a few cross wires! no pun intended.
    cant see that your inverter would be wired to supply the water heater, the power drain would kill your batteries in double quick time. why would you want the inverter to power you water heater, surely thats done by gas while motoring ( assuming you have a sucmotion regulator fitted ) and EHU when stationary?
  3. nicaf
    nicaf Read Only Funster
    Mar 4, 2012
    7
    5
    Chelmsford, Essex
    The Burstner will have the Alde central heating system which also incorporate a heat exchanger that uses hot water from the engine to provide space heating to the habitation area, and also provide hot water.
    The inverter is something entirely separate the enables you to run 240 volt appliances from the 12 volt supply. You will need to check the capacity of the inverter when assessing what electrical appliances you can run
  4. footballvanbond
    Feb 19, 2014
    INVERKEITHING
    thanks I meant the heat exchanger not Inverter DOH .... does the charging work with the control panel off or on?
