rattling noise from fire (1 Viewer)
N
Nobody
when driving over uneven roads annoying noise coming from fire as if it is loose any ideas to cure it
Jul 17, 2009
188
155
We had just the same problem when picking our MH up from new. Took it back to the dealer to complain, they just removed the front, if I remember correctly there are two screws under the front panel, bent the metal fins (which direct the air) to a more accute angle which prevents the fins from chattering on the front panel (which is what the problem was) if you can't remove front panel get a screw driver and bend the fins down until they don't touch.
