Rare Spares Handbrake Extender
Discussion in 'Tech/Mech General' started by MikeandCarolyn, May 6, 2010.
  1. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    I know quite a few Funsters have these-hope this is of help :Smile:
    When I bought mine,I fitted it on the coldest day of the year and managed to overtighten the bolts so that one side of the casing split :cry:
    When I got the new piece (£10) I was very carefull not to overtighten it !! so much so,that after a couple of months I noticed more 'play' in the lever and found that the bolts had loosened. I have now retightened them using Threadlock -hopefully that's it sorted.:BigGrin:
    Mike.
  2. ingram
    ingram Read Only Funster
    Aug 9, 2008
    87
    I have one of these and although very well made, it can, as others have mentioned previously be 'knocked off' accidentally. I am always very careful exiting the cab if I haven't folded the lever.......... this is leading up to M.O.T. testing with this lever fitted. Has anyone with a Rarespares entered their 'van for an M.O.T. with it fitted and if so were there any comments from the tester?
    Reading the MOT testers manual here:--
    http://www.motuk.co.uk/manual_310.htm
    it appears to me that there *may* be an area of possible failure relating to "a locking or retaining device is insecure or missing."
    and also. possibly, " when knocked, the lever is not held in the "on" position " the latter after testing by knocking "the top and each side of the lever and check that the lever stays in the "on" position".
    perhaps George, our resident MOT man, would be able to comment ....
    Harvey
  3. Robinhood
    Robinhood Read Only Funster
    Mar 7, 2010
    159
    Sherwood Forest
    Mine was tested year before last with the extender in place (and its action was explained to the tester in advance). No issues arose - though, in common with many Sevel vans with 'Drum in Hat' parking brakes, the brake efficency was marginal.
    This year, to avoid any potential issues, I carefully serviced the parking brake mechanism before the test, and temporarily removed the extender (since it is easier to apply the brake hard without it, especially if you haven't learnt the required action). Sailed through with the whole system locking this time.
    When I re-installed the extender (wouldn't be without it in general use), I managed to do exactly what the original poster did, and overtightened - I probably got the other side of the moulding as a replacement from Rare Spares. :Cool:
    I don't experience any issues with exiting the vehicle, as my A class does not have a drivers side door.
  4. 1948
    1948 Read Only Funster
    Dec 3, 2009
    444
    46
    surrey
    where did you get yours for £10 the ones i saw at peterborough show was £40
  5. ingram
    Aug 9, 2008
    87
    I read it that Mike & Carolyn paid £10 for a replacement part. not for the whole thing!
    I saw some handbrake extenders for sale at Peterborough but they weren't the 'Rarespares' ones, they were the 'others' which are cheaper, but don't fold down.
    I think that removing the extender for the MOT may be a good idea anyway because the grease will be easier to clean off the original lever.:Laughing:
    My son is an MOT tester, perhaps I'll ask him .......
    Harvey
  6. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,739
    5,967
    Mansfield,Notts
    Just to clarify
    Each and every parking brake lever/mechanism and design is judged on its own merits
    The fitting of an extender in its self, is not a reason for rejection,
    However dont blame the tester if it breaks trying to achive maximun effort, to get you a pass:Doh:
    As stated above in another post a correctly serviced and set parking brake should lock with minimal effort on the lever, getting underneath and taking the slack out of the cable is NOT adjusting or improving your brakes, as many think it does:RollEyes:
    Geo
  7. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    getting underneath and taking the slack out of the cable is NOT adjusting or improving your brakes, as many think it is
    ....and as I found out many years ago, can have a serious impact on the/any self adjusting properties!
    To explain, fitting a new hand break cable to my first car with self adjusting (drum) brakes and set it up so all worked well only to find the while the hand brake worked the foot brake went to the floor and didn't stop the car, fortunatly I test carfully any thing, unlike a mate who once shot of after brake work and ended up testing them against a wall:Doh:
  8. MikeandCarolyn
    Mar 18, 2008
    2,171
    1,463
    Correct-thanks :BigGrin:
    Mike
